Hello
If someone knows the best (easiest to code) way to do a half-precision GEMM using tensor cores, I’d really appreciate any help.
It seems that, about a year ago, this wasn’t possible in cutlass (page 4):
https://developer.download.nvidia.com/video/gputechconf/gtc/2019/presentation/s9306-extreme-signal-processing-performance-using-tensor-cores-and-astronomical-imaging-on-gpus.pdf
And, the best approach was to map the problem to an equivalent real problem. On the other hand, planar complex GEMMs are mentioned in the latest cutlass profiler:
https://github.com/NVIDIA/cutlass/blob/fb335f6a5fe19d22a834b19706707f4489427482/tools/profiler/src/gemm_operation_profiler.cu#L49
But, I suspect (line 139 in the above file), that only the basic GEMM is covered.
Cutlass aside, it seems that cublas will handle the problem:
https://docs.nvidia.com/cuda/cublas/index.html#cublasLt-example-planar-complex
That is, so long as the input and output are separated into real and imaginary parts. Ideally, I’d like to use an interleaved layout.
If you have a view on the best approach, I’d welcome the input.
Gary
The easiest way would be to use cublasLt. You are correct in that cublasLt currently requires planar layout. There is a function to help transform from interleaved to planar but with a negative impact to performance.
You should also have to functionality in CUTLASS to do what you’re asking. I think you should be able to mod https://github.com/NVIDIA/cutlass/blob/fb335f6a5fe19d22a834b19706707f4489427482/examples/08_turing_tensorop_gemm/turing_tensorop_gemm.cu pretty easily.
If you’re able to come to GTC 2020, you should be updated presentations on both libraries I think.
Thanks–could you please link to the interleaved-to-planar function?
There is another interesting presentation on this topic, for anyone following along:
“Towards Half-Precision Computation for Complex Matrices”
https://www.icl.utk.edu/files/publications/2019/icl-utk-1308-2019.pdf
The planar <-> interleaved functionality is in mnicely’s complex half precision example:
https://github.com/mnicely/cublasLt_examples/blob/master/cublasLt_C16F_TCs.cu
