Hello all,
I’m trying to write a kernel that requires the use of doubles for accuracy. To do this, I have a 280 and have specified -arch sm_13 on the compile line of nvcc. When I specify compute 1.3, the kernel doesn’t execute quoting “invalid device function”… but when I specify sm_11, the kernel runs fine but returns nonsense due to the accuracy problems I assume.
To double check that it wasn’t my particular function, I’ve tested it using a blank kernel, i.e.
global void TheBestKernelEverRunOnAGPU() { int x=0; }
but this one also only runs when specifying sm_11 instead of sm_13. Any ideas?
Cheers,
-Matt
