Hi Folks
My cluster got powered off due to lab outage. After powering on Head node , I was trying to get the compute nodes up , they all the stuck at the screenshot attached , please let me know if you need more information.
I tried the below link , its still not working
please refer the output below as well
Wed Sep 28 15:03:13 2022 [notice] bright88: node002 [ INSTALLER_UNREACHABLE ] (ldlinux.c32 from bright88)
[bright88]% category use default
[bright88->category[default]]% set bootloaderprotocol tftp
[bright88->category*[default*]]% commit
Wed Sep 28 15:07:02 2022 [notice] bright88: Service dhcpd was restarted
[bright88->category[default]]% show
Parameter Value
Name default
Nodes 2
Revision
Use exclusively for
User node login ALWAYS
Filesystem mounts <6 in submode>
Time zone Asia/Seoul (base)
Roles <0 in submode>
Static routes <0 in submode>
GPU Settings <0 in submode>
Filesystem exports <0 in submode>
Services <0 in submode>
Kernel modules 72 (software image:default-image)
Default gateway 192.168.61.88 (network: internalnet)
Management network internalnet
Software image default-image
Node installer disk no
Install boot record no
Install mode AUTO
New node install mode FULL
Name servers
Time servers
Search domain
Exclude list full install <234B>
Exclude list sync install <1.33KiB>
Exclude list update <4.2KiB>
Exclude list grab <1.70KiB>
Exclude list grab new <1.35KiB>
Exclude list manipulate script <0B>
Initialize script <0B>
Finalize script <3.4KiB>
Data node no
Allow networking restart no
Version config files no
Kernel version 3.10.0-1160.11.1.el7.x86_64 (software image:default-image)
Kernel parameters biosdevname=0 net.ifnames=0 nonm acpi=on nicdelay=0 rd.driver.blacklist=nouveau xdriver=vesanamespace.unpriv_enable=1 user_namespace.enable=1 (software image:default-image)
Kernel output console tty0 (software image:default-image)
IO scheduler
Boot loader syslinux
Boot loader protocol TFTP
Boot loader file
FIPS no
BMC Settings <submode>
SELinux Settings <submode>
Disk setup <1.07KiB>
Hardware RAID configuration <0B>
Scaling governor
BIOS setup <0B>
Provisioning associations <1 internally used>
Notes <0B>
