I have written some code using single precision floating point calculations. As I now have a GTX 280, I wanted to switch to double precision. Just exchanging “float” by “double” led to an “unspecified launch failure”.
I modified the template from the SDK to produce a minimal code that still leads to this problem, but now I’m stuck. I would appreciate any help on this.
Here is the output I get:
If I change the TYPE define to float, the error doesn’t occur. Likewise, if I remove the cudaThreadSynchronize() in the double precision version, the error doesn’t occur either.
I use the makefile from the SDK, but added the line “NVCCFLAGS += ‘–gpu-architecture=sm_13’”. The makefile and code are attached to this post.
Please note, that the current kernel doesn’t do anything meaningful. In my real code, I need the two loops and everything, but I removed large parts to simplify it.
Any idea, what’s wrong?
jackerma
nvcc version: release 2.1, V0.2.1221
OS: suse 11.1
double_error.zip (4.44 KB)
