Please let me confirm the following question.
[Question]
Would you please teach me the way to update the device tree compiled by Jetson TX2?
Note: I have used the JetPack 3.3 for TX2.
Or should we overwrite the “tegra186-quill-p3310-1000-c03-00-base.dtb” with the new one on host PC and run the flash.sh script with the following command like following link??
sudo ./flash -r -k kernel-dtb jetson-tx2 mmcblk0p1
Please refer to Jetson/TX2 DTB - eLinux.org. You should replace tegra186-quill-p3310-1000-c03-00-base.dtb or tegra186-quill-p3310-1000-a00-00-base.dtb dependent on which one is used.
Thank you for your response.
According to your comments, we do not have a way to update the dtb files on Jeton TX2. We must use the flash.sh file to update it.
Is my understanding correct?
