I’m new here. And I’m confused with some basic stuffs.
1, a device is a GPU? and multiple devices are many GPUs?
2, GeForce 8800 Ultra has 16 multiprocessors and 128 stream processor, so per multiprocessor has 8 stream processor? is the concept of stream processor the same as core in CPU?
3, a kernel executes a grid of threads, and a grid is consist of many blocks. A block can be executed in only one multiprocessor, is it possible several blocks be executed in the same multiprocessor?
Yes, each multiprocessor is made up of 8 processors on current architectures. The concept of a processor here is quite different to a CPU core, since each of the processors of a given multiprocessor on the GPU is usually running the same instruction but on different data (SIMD). CPUs can run different code on each core.
Yes, a multiprocessor can execute multiple blocks concurrently, and this is advantageous for performance - when one block stalls waiting for a global memory read or due to thread synchronization, the multiprocessor can switch and execute a different block instead.
Is this all not adequately explained in the programming guide?
Each kernel should define its grid structure and it is fixed when kernel is executed. Is that right
The kernel will be defined though __global__function, so if i have 2 global functions (like a process data in 2 step), that mean i have 2 kernel, i can define different grid-block structure for each one. Is that right
Can i reused the result of the first kernel for the second one so that i don’t have to copy result back to the main(host) memory and reinitilize the memory for the second kernel (global function)
I have confusion with the call of global function
Func<<<Dg, Db, Ns>>> (parametter)
while in the spec Dg, Db is dim3 but i alway see in the code something like
we have a unique way to compute the thread_id. So why don’t we have an inline, or
optimized function to compute this, and that can work more efficient and reduce confusion and error that may arise with a customized function.
