Hi I’m having trouble getting my TX1 to connect to Wifi on boot. This is after a flash using Jetpack (64bit). After it boots I can use these commands to connect to an access point:
$ wpa_passphrase MYSSID MYPASSWORD > wpa.conf
$ sudo wpa_supplicant -Dnl80211 -iwlan0 -cwpa.conf -B
$ sudo dhclient -r
$ sudo dhclient wlan0
I’ve tried adding all but the pw generator to /etc/rc.local, and changing /etc/network/interfaces to this:
auto wlan0
iface wlan0 inet dhcp
wpa-conf /home/ubuntu/wpa.conf
iface default inet dhcp
With the /etc/network/interfaces changes on boot I see:
Waiting for network configuration…
Waiting up to 60 more seconds for network configuration…
Booting system without full network configuration…
Is it missing the driver switch? I can’t get it to connect without using nl80211 (default is wext).
If I type: $ sudo ifconfig wlan0 shows up, I’ve also ran $ sudo ifconfig wlan0 up. When I run $ sudo ifconfig I see wlan0 as well as wlan0:avahi?
During boot I also see this:
systemd-udevd /sbin/initcl start nvwifibt SUBTASK=register BCMCHIP=0x4354 [540] terminated by signal 1 (Hangup)
systemd-udevd /sbin/initcl start nvwifibt SUBTASK=register BCMCHIP=0x4354 [541] terminated by signal 1 (Hangup)
Stopping NVIDIA bluetooth wifi init script
What is the correct procedure for connecting to Wifi on boot? Should I be using wpa_supplicant or is there an alternative method that works?
