Hello !
I use the ConnectX-3 Cards via a PCI-e 3.0x8 connector card in Windows 10, it works well. Unfortunately, Windows 10 recognized the ConnectX-3 Cards as an ejectable device. The WinOF driver 5.50.53000 has been correctly installed.
Does anyone knows how to fix it ?
Hello autonomous120,
Thank you for sharing your question.
This behavior of ConnectX-3 as an ejectable device has been seen in several Windows OS versions. It’s a normal behavior and can’t be changed. Furthermore, there is no need to change anything, you can use the adapter as for your needs normally.
Best Regards,
Nvidia Enterprise Support
