Hey,
I am trying to offload a simple XDP Program to hardware on my ConnectX-6 Dx Crypto and Secure boot device.
e.g. the xdp1 kernel sample (linux/samples/bpf at master · torvalds/linux · GitHub):
idp@shs01-muc5-fw:~/xdp/linux/samples/bpf$ sudo ./xdp1 -N enp99s0f1
libbpf: elf: skipping unrecognized data section(16) .eh_frame
libbpf: elf: skipping relo section(17) .rel.eh_frame for section(16) .eh_frame
link set xdp fd failed
Or directly with ip:
idp@shs01-muc5-fw:~/xdp/t1$ sudo /opt/mellanox/iproute2/sbin/ip link set dev enp99s0f1 xdp obj simple.c.elf section simple verbose
Prog section ‘simple’ loaded (5)!
Type: 6
Instructions: 2 (0 over limit)
License: WTFPL
Verifier analysis:
0: (b7) r0 = 2
1: (95) exit
processed 2 insns (limit 1000000) max_states_per_insn 0 total_states 0 peak_states 0 mark_read 0
RTNETLINK answers: Invalid argument
According to dmesg this is related to IPSec offloading:
[ 3584.043640] mlx5_core 0000:63:00.1 enp99s0f1: can’t set XDP with IPSec offload
How do I get XDP offloading to work, with or without IPSec?
ethtool -k:
idp@shs01-muc5-fw:~/xdp/linux/samples/bpf$ /opt/mellanox/ethtool/sbin/ethtool -k enp99s0f1
Features for enp99s0f1:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp-mangleid-segmentation: off
tx-tcp6-segmentation: on
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-gre-csum-segmentation: on
tx-ipxip4-segmentation: on
tx-ipxip6-segmentation: on
tx-udp_tnl-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
tx-esp-segmentation: on
tx-udp-segmentation: on
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off
rx-all: on
tx-vlan-stag-hw-insert: on
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: on [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off
esp-hw-offload: on [fixed]
esp-tx-csum-hw-offload: on [fixed]
rx-udp_tunnel-port-offload: on
tls-hw-tx-offload: on
tls-hw-rx-offload: off [fixed]
rx-gro-hw: off [fixed]
tls-hw-record: off [fixed]
Simple XDP:
#include <linux/bpf.h>
#define __section(NAME) attribute((section(NAME), used))
__section(“license”)
char __license = “WTFPL”;
__section(“simple”) int xdp_simple(struct xdp_md *ctx) {
return XDP_PASS;
