If I run tensorflow just after start I have sufficient memory
I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:874] ARM64 does not support NUMA - returning NUMA node zero
I tensorflow/core/common_runtime/gpu/gpu_device.cc:885] Found device 0 with properties:
major: 6 minor: 2 memoryClockRate (GHz) 1.3005
pciBusID 0000:00:00.0
Total memory: 7.67GiB
Free memory: 6.01GiB
But as I execute it multiple times it gradually decreases to the point tensorflow would not run.
For example in the next run:
Closing the terminal does not help and I have to restart the system.
Is it possible to clean up memory by using some command? This happens even if my programs
exits correctly. Can I run some command to clear the memory?
