Hey, I am integrating my model to make a Holoscan sdk based application for real-time inference. But I am having one issue which I am not sure how to solve efficiently. Currently my model inputs images/frames with shape: [BatchSize, Channels, Height, Width] but the InferenceOp Operator expects the input to be of the shape: [Batch_Size, Height, Width, Channel]. Is there a zero copy way to covert the output tensor from FormatconverterOp to my required shape before passing it into InferenceOP operator.
Hi Dan
Thanks for your question and interest in holoscan SDK .
Unfortunately the FormatconverterOp is not able to do this at this time and it does a copy.
May be you can try this code below that would to the conversion for you. It does use cupy to run on the gpu but I am not sure if all operations avoids copying.
Hope that helps
class My_TransposeOp(Operator):
#Custom Holoscan operator to transpose a tensor.
def __init__(self, fragment, *args, perm=(1, 0, 2), keyname_in_message="out_tensor", **kwargs):
self.perm = perm # The desired output dimension order
self.keyname_in_message = keyname_in_message
super().__init__(fragment, *args, **kwargs)
def setup(self, spec: OperatorSpec):
spec.input("in_tensor")
spec.output("out_tensor")
def compute(self, op_input, op_output, context):
message = op_input.receive("in_tensor")
keyname = self.keyname_in_message
if isinstance(message, dict):
in_holoscan_tensor = message[keyname]
else:
in_cupy_array = cp.asarray(in_holoscan_tensor)
out_cupy_array = cp.transpose(in_cupy_array, self.perm)
# Ensure row-major (C-contiguous) memory layout for Holoviz
out_cupy_array = cp.ascontiguousarray(out_cupy_array)
op_output.emit({keyname: out_cupy_array}, "out_tensor")
