I tried to convert model.int8.onnx to tensorRT engine, but encountered error…
The model was already quantized in onnxRT framework and it has Quantized/Dequantized linear layer, whuch are supported by tensorRT accoring to this page (onnx-tensorrt/docs/operators.md at main · onnx/onnx-tensorrt · GitHub)
I used command:
./trtexec --onnx=test.int8-onnx-calibrated.onnx --saveEngine=engine.trt
I thoght that it could be converted … But errors appeared, which are following.
It’s not possible to convert int8-onnx model to trt engine?
Best regards.
[02/16/2023-18:18:25] [I] [TRT] ----------------------------------------------------------------
[02/16/2023-18:18:25] [I] [TRT] Input filename: test.int8-onnx-calibrated.onnx
[02/16/2023-18:18:25] [I] [TRT] ONNX IR version: 0.0.6
[02/16/2023-18:18:25] [I] [TRT] Opset version: 11
[02/16/2023-18:18:25] [I] [TRT] Producer name: onnx.utils.extract_model
[02/16/2023-18:18:25] [I] [TRT] Producer version:
[02/16/2023-18:18:25] [I] [TRT] Domain:
[02/16/2023-18:18:25] [I] [TRT] Model version: 0
[02/16/2023-18:18:25] [I] [TRT] Doc string:
[02/16/2023-18:18:25] [W] [TRT] onnx2trt_utils.cpp:364: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[02/16/2023-18:18:25] [E] Error[2]: [scaleNode.cpp::getChannelAxis::27] Error Code 2: Internal Error (features.0.bias_DequantizeLinear_quantize_scale_node: out of bounds channel axis 1. Number of input dimensions is 1.)
[02/16/2023-18:18:25] [E] [TRT] ModelImporter.cpp:720: While parsing node number 0 [DequantizeLinear -> "features.0.bias"]:
[02/16/2023-18:18:25] [E] [TRT] ModelImporter.cpp:721: --- Begin node ---
[02/16/2023-18:18:25] [E] [TRT] ModelImporter.cpp:722: input: "features.0.bias_quantized"
input: "features.0.bias_quantized_scale"
input: "features.0.bias_quantized_zero_point"
output: "features.0.bias"
op_type: "DequantizeLinear"
[02/16/2023-18:18:25] [E] [TRT] ModelImporter.cpp:723: --- End node ---
[02/16/2023-18:18:25] [E] [TRT] ModelImporter.cpp:726: ERROR: ModelImporter.cpp:179 In function parseGraph:
[6] Invalid Node - features.0.bias_DequantizeLinear
[02/16/2023-18:18:25] [E] Failed to parse onnx file
[02/16/2023-18:18:25] [I] Finish parsing network model
[02/16/2023-18:18:25] [E] Parsing model failed
[02/16/2023-18:18:25] [E] Failed to create engine from model.
[02/16/2023-18:18:25] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8205] # ./trtexec --onnx=test.int8-onnx-calibrated.onnx
A clear and concise description of the bug or issue.
Environment
TensorRT Version:
GPU Type:
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version:
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
