Description
We have converted an object detection model from TensorFlow to ONNX, and now are trying to convert to TensorRT. The conversion fails with the following error:
[TensorRT] WARNING: onnx2trt_utils.cpp:217: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[TensorRT] WARNING: onnx2trt_utils.cpp:243: One or more weights outside the range of INT32 was clamped
[TensorRT] ERROR: Equal__2701:0: shape tensor must have type Int32.
[TensorRT] ERROR: Equal__2846:0: shape tensor must have type Int32.
[TensorRT] ERROR: Equal__1023:0: shape tensor must have type Int32.
[TensorRT] ERROR: Equal__1032:0: shape tensor must have type Int32.
[TensorRT] ERROR: Equal__1039:0: shape tensor must have type Int32.
[TensorRT] ERROR: Equal__1071:0: shape tensor must have type Int32.
[TensorRT] ERROR: Builder failed while analyzing shapes.
Engine <tensorrt.tensorrt.INetworkDefinition object at 0x7f7ecd3e68>
File "getplan.py", line 20, in <module>
eng.save_engine(engine, engine_name)
File "/srv/demo/Demos/scripts/tensorrt_uff/ai-scripts/engine.py", line 27, in save_engine
buf = engine.serialize()
AttributeError: 'NoneType' object has no attribute 'serialize'
We also tried converting with ‘onnx2trt’ and got the error below:
Input filename: model1.onnx
ONNX IR version: 0.0.7
Opset version: 12
Producer name: tf2onnx
Producer version: 1.6.2
Domain:
Model version: 0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.7) than this parser was built against (0.0.6).
Parsing model
[2020-07-08 13:13:07 WARNING] /srv/demo/Demos/scripts/tensorrt_uff/ai-scripts/onnx2trt/onnx-tensorrt/onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[2020-07-08 13:13:07 WARNING] /srv/demo/Demos/scripts/tensorrt_uff/ai-scripts/onnx2trt/onnx-tensorrt/onnx2trt_utils.cpp:246: One or more weights outside the range of INT32 was clamped
While parsing node number 852 [Unsqueeze -> "MultipleGridAnchorGenerator/stack_1_Unsqueeze__1596:0"]:
ERROR: /srv/demo/Demos/scripts/tensorrt_uff/ai-scripts/onnx2trt/onnx-tensorrt/onnx2trt_utils.cpp:188 In function convertAxis:
[8] Assertion failed: axis >= 0 && axis < nbDims
We also tried conversion using trtexec, and are getting the following error:
[07/08/2020-09:42:10] [V] [TRT] ImporterContext.hpp:122: Registering layer: MultipleGridAnchorGenerator/Meshgrid_2/Tile for ONNX node: MultipleGridAnchorGenerator/Meshgrid_2/Tile
[07/08/2020-09:42:10] [V] [TRT] ImporterContext.hpp:97: Registering tensor: MultipleGridAnchorGenerator/Meshgrid_2/Tile:0 for ONNX tensor: MultipleGridAnchorGenerator/Meshgrid_2/Tile:0
[07/08/2020-09:42:10] [V] [TRT] ModelImporter.cpp:182: MultipleGridAnchorGenerator/Meshgrid_2/Tile [Tile] outputs: [MultipleGridAnchorGenerator/Meshgrid_2/Tile:0 -> ()],
[07/08/2020-09:42:10] [V] [TRT] ModelImporter.cpp:103: Parsing node: MultipleGridAnchorGenerator/stack_1_Unsqueeze__1596 [Unsqueeze]
[07/08/2020-09:42:10] [V] [TRT] ModelImporter.cpp:119: Searching for input: MultipleGridAnchorGenerator/Meshgrid_2/Tile:0
[07/08/2020-09:42:10] [V] [TRT] ModelImporter.cpp:125: MultipleGridAnchorGenerator/stack_1_Unsqueeze__1596 [Unsqueeze] inputs: [MultipleGridAnchorGenerator/Meshgrid_2/Tile:0 -> ()],
ERROR: onnx2trt_utils.cpp:185 In function convertAxis:
[07/08/2020-09:42:10] [E] Failed to parse onnx file
[07/08/2020-09:42:10] [E] Parsing model failed
[07/08/2020-09:42:10] [E] Engine creation failed
[07/08/2020-09:42:10] [E] Engine set up failed
Environment
TensorRT Version:
ii graphsurgeon-tf 7.1.0-1+cuda10.2 arm64 GraphSurgeon for TensorRT package
GPU Type: Jetson Nano Jetpack 4.4
Nvidia Driver Version: Jetson Nano Jetpack 4.4
CUDA Version: 10.2
CUDNN Version:
Operating System + Version:
Linux svetlana-desktop 4.9.140-tegra #1 SMP PREEMPT Wed Apr 8 18:10:49 PDT 2020 aarch64 aarch64 aarch64 GNU/Linux
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable): 1.15
Any help would be appreciated.
Thank you
Svetlana
