I’m running into an issue when exporting a model from pytorch (version 1.0.0) to onnx, and then importing into tensorrt (version 5.0.3 in jetpack 4.1.1).
In pytorch/onnx, the convtranspose2d layer (with parameters: kernel size = 3, stride = 2, padding = 1, output padding = 1, dilation = 1; input tensor dimension 1 x 256 x 16 x 32) produces output tensors with dimension 1 x 256 x 32 x 64 (the desired size).
When imported into tensorrt, the layer produces output tensors with dimension 1 x 256 x 31 x 63.
Looking at pytorch’s documentation (torch.nn — PyTorch 1.12 documentation), the given formula for output dimension (eg, for height) is: (H_in - 1)stride - 2padding + kernel_size + output_padding. plugging in our parameters gives 32.
Looking at tensorrt’s documentation on the deconvolution layer (NVIDIA Documentation Center | NVIDIA Developer - section A.1.5), the given formula for output dimension is: (H_in -1)stride + t - 2padding, where t = kernel_size + dilation*(kernel_size-1). there are a few confusing bits here:
plugging in our parameters doesn’t actually give 31, but 33. does the padding in this formula sum both the input padding and output_padding?
this differs from the pytorch formula only in the last bit: pytorch adds output_padding, and tensorrt adds dilation*(kernel_size-1) instead
Any thoughts on how we can get these two APIs to output the same dimensions here, and why the tensorrt dimension is not as expected?
One addition: I looked at the pytorch source code to see what happened to the dilation term in their dimension equation and it looks like their docs are out of date (though the above equation holds true in our case where dilation=1). The equation in the source is:
I’m running into this issue as well, with the same pytorch => ONNX => TensorRT path. I updated my model to avoid any ConvTranspose2d with padding, but I’d love to see a proper fix.
