Using argus from jetson MMAPI, I have this piece of code working:
UniqueObj<Frame> frame(iFrameConsumers[i]->acquireFrame());
IFrame *iFrame = interface_cast<IFrame>(frame);
if (!iFrame)
break;
NV::IImageNativeBuffer *iNativeBuffer =
interface_cast<NV::IImageNativeBuffer>(iFrame->getImage());
if (!iNativeBuffer)
ORIGINATE_ERROR("IImageNativeBuffer not supported by Image.");
if (!m_dmabufs[i])
std::cout<< "Dmabufs\n";
batch_surf[i] = NULL;
m_dmabufs[i] = iNativeBuffer->createNvBuffer(
iEglOutputStreams[i]->getResolution(),
NvBufFMT_,
NVBUF_LAYOUT_PITCH
if (!m_dmabufs[i])
std::cout<< "Failed to create NvBuffer\n";
// CONSUMER_PRINT("\tFailed to create NvBuffer\n");
if (-1 == NvBufSurfaceFromFd(m_dmabufs[i], (void**)(&batch_surf[i])))
ORIGINATE_ERROR("Cannot get NvBufSurface from fd");
else if (iNativeBuffer->copyToNvBuffer(m_dmabufs[i]) != STATUS_OK)
ORIGINATE_ERROR("Failed to copy frame to NvBuffer.");
frN++;
std::cout<< "Frame: "<< frN <<"\n";
NvBufSurface *nvbuf_surf = 0;
int ret = NvBufSurfaceFromFd(m_dmabufs[0], (void**)(&nvbuf_surf));
if (ret)
printf( "NvBufSurfaceFromFd failed");
return -1;
I am able to copy the data from nvbuf_surf using
NvBufSurfaceParams *params = &nvbuf_surf->surfaceList[0]
to my cuda or cpu array with no problem.
However the data on nvbuf_surf seems to be on CPU memory (or accessible only by cpu!). I need to receive the image data from the camera on the cuda memory, how can I do it?
Besides, I would ideally need to transfer the image data to my custom cuda memory allocated array from the iFrame. Is it possible? (From IFrame *iFrame = interface_cast<IFrame>(frame) I mean).
The below code is what I am trying to achieve, but this code throws some error (Invalid argument) in cudaMemcpy2D, so I don’t know what way is the correct way to copy the data direclty from iFrame?
unsigned char* devicePtr;
void* nativePtr = iFrame->getImage();
cudaMalloc((void**)&devicePtr, 4 * CAM_H * CAM_W * sizeof(unsigned char));
cudaError_t cpy2d_error = cudaMemcpy2D(devicePtr,
/* */ 4 * CAM_W * sizeof(unsigned char),
/* */ nativePtr,
/* */ CAM_H,
/* */ cudaMemcpyDeviceToDevice
std::cout << "cpy2D_error: " << cudaGetErrorString(devicePtrcpy2d_error) << std::endl;
Thank you so much.
