Hi all
I want to store in contant memory a float value. I declare it as:
__constant__ float RADIUS;
And then I want to copy the value “radius” to RADIUS as:
cutilSafeCall(cudaMemcpyToSymbol(RADIUS,radius,sizeof(float),0,cudaMemcpyHostToDevice));
The compiler out:
Using arrays I have no problem. But does anybody know how can I copy just one value to constant memory?
Thank you everyone for your time.
PD: If it is possible I don’t want to pass it by kernel parameter.
I tried this:
cutilSafeCall(cudaMemcpyToSymbol(&RADIUS,&radius,sizeof(float),0,cudaMemcpyHostToDevice));
It complies fine, but the execution outs:
Does anyboydy know why?
Thank you again
Copy an array of floats of size 1.
BTW, why not use a simple define???
eyal
Tigga
3
Just because it’s going into constant memory doesn’t mean it’s a compile time constant.
Silly me :"> you’re correct of course… :)
That’s what I did before and It works, but I don’t like that way. It’s just for doing things the best way.
fbuckle
7
I think that you can do:
cutilSafeCall(cudaMemcpyToSymbol("RADIUS",radius,sizeof(float),0,cudaMemcpyHostToDevice));
This is from the reference manual:
symbol can either be a variable that resides in
global or constant memory space, or it can be a character string, naming a variable that resides in global or constant
memory space.
Hope this helps.
You’re right. Thanks for the information. Anyway, my problem wasn’t this. I finally did it like this:
cutilSafeCall(cudaMemcpyToSymbol(*(&RADIUS),&radius,sizeof(float),0,cudaMemcpyHostToDevice));
This works fine.
On the other hand this only works with contant memory but in global memory I do:
cutilSafeCall(cudaMalloc((void**)finishedDevice, sizeof(bool)));
bool finished=false;
cutilSafeCall(cudaMemcpy(&finishedDevice,&finished,sizeof(bool),cudaMemcpyHostToDevice));
This compiles but I get an error in execution time of “invalid device pointer”. Any sugestions?
Thank you everyone.
Wookai
9
I don’t know what type is your finishedDevice, but if it’s a simple pointer, you miss one & :
bool* finishedDevice;
cutilSafeCall(cudaMalloc((void**)&finishedDevice, sizeof(bool)));
It’s not a pointer. Just a primitive.
bool finishedDevice;
Thank you anyone.
