I have a derived type which has a parameter p. This p represents a 3D array. I would like to copy this directly into a data region as so:
!$acc data region copyin(b%p(1:n,1:n,1:n))
But I get a syntax error on compilation. Is there any way to do this that avoids just copying b%p into an allocatable array and copying this new array in? Could I copy a pointer to the array in?
I’ve been told by our main OpenACC developer that using a derived type array member in the copyin directive will be possible in the 14.4 release of PGI. You might want to pick up that update in a few weeks, and see if this works for you then.
Until then, you will have to use a workaround, such as assigning the data to a temporary array. (Not ideal, I know.)
Hi, any idea of a date for the release of 14.4? Or is there any chance of a prerelease version I could download? I have a report deadline on Thursday and my results/code would look rather better with the compiler fixes and added features that 14.4 will offer me!
