e.ping
January 9, 2009, 12:54am
#1
Hi all,
When I try to copy memory from host to a 3D array, I get an cudaErrorInvalidValue. Code snippet as follow:
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<float>(); // texture elements are float
// dimensions of texture
cudaExtent extent;
extent.width = C; // 51
extent.height = ZM; // 3
extent.depth = ZN; // 3
CUDA_SAFE( cudaMalloc3DArray(&Z_d, &channelDesc, extent) ); // allocate GPU memory as a 3D cuda-array -> success
cudaError_t errCode = cudaMemcpyToArray(Z_d, 0, 0, Z, C*ZM*ZN*sizeof(T), cudaMemcpyHostToDevice); // --> cudaErrorInvalidValue
My feeling is I should be using a function cudaMemcpyToArray3D, but it doesn’t exist
Any advice would be greatly appreciated!
Thanks,
Greg
e.ping
January 14, 2009, 1:27am
#2
Hi tried to reduce my test as much as possible…
when runs it returns: Call to ‘cudaMemcpyToArray’ returned ‘invalid argument’
Any idea how I can copy memory to a 3d array?
Thanks a lot,
Cheers,
Greg
test.cu:
// compile with "nvcc test.cu"
// this exmaple shows that copying memory to a 3d texture fails
#include <cuda.h>
#include <stdio.h>
#include "test_kernel.cu"
void safecall(cudaError_t call, const char* fname) {
printf("Call to '%s' returned '%s'\n", fname, cudaGetErrorString(call));
if (call != cudaSuccess) exit(0);
int main() {
const int N = 3, M = 3, C = 5; // size of the texture: MxNxC
// grid and block dimensions
dim3 gridSize(C, 1);
dim3 blockSize(8, 8);
// allocate memory on host
float Z[N*M*C];
// pointer to texture memory on device
cudaArray *Z_d;
// setup texture dimension
cudaExtent extent;
extent.width = C;
extent.height = M;
extent.depth = N;
// texture channel descriptor
// memory allocation for texture, on GPU
safecall(cudaMalloc3DArray(&Z_d, &channelDesc, extent), "cudaMalloc3DArray"); // allocate GPU memory as a 3D cuda-array
// copy from host memory to device memory
safecall(cudaMemcpyToArray(Z_d, 0, 0, Z, C*M*N*sizeof(float), cudaMemcpyHostToDevice), "cudaMemcpyToArray" );
// bind memory to the texture
safecall(cudaBindTextureToArray(tex, Z_d, channelDesc), "cudaBindTextureToArray" );
// dummy kernel call
test_kernel<<<gridSize, blockSize>>>();
return 0;
test_kernel.cu:
// texture declaration
static texture<float,3,cudaReadModeElementType> tex;
// empty kernel
__global__ void test_kernel() {}
e.ping
January 14, 2009, 1:50am
#3
In case it’s useful to someone I solved my problem (a simple example is in the SDK in ‘simpleTexture3D’)…
In summary, instead of using cudaMemcpyToArray one has to do something like that:
cudaMemcpy3DParms copyParams = {0};
copyParams.srcPtr = make_cudaPitchedPtr((void*)Z, M*sizeof(float), M, N);
copyParams.dstArray = Z_d;
copyParams.extent = extent;
copyParams.kind = cudaMemcpyHostToDevice;
//safecall(cudaMemcpyToArray(Z_d, 0, 0, Z, C*M*N*sizeof(float), cudaMemcpyHostToDevice), "cudaMemcpyToArray" );
safecall( cudaMemcpy3D(©Params), "cudaMemcpy3D" );
maybe this should be clarified in the documentation?
Cheers,
Greg
Thank you.
I was also having this problem and your solution worked.
Will someone at NVIDIA please note this and fix the documentation. 3D textures
badly needs some working examples in the doc. Thank you.
MW
There is something strange in this code. in the extent you define the order of the coordinates to be C,M,N
but then when creating the pitched pointer M and N are the first coordinates.
