core dumps when tweaking Deepstream config file (Solved)
Question regarding configuration changes to DeepStream 1.5 on the Jetson TX2:
I was able to run the demo application nvgstiva-app with the provided config file. Next, I would like to make some simple changes to the Deepstream config file (no custom plugins, etc) - just use the primary inference engine (without any secondary inference engines), but use an object detection network for the primary engine.
In particular, the detectnet from the “Two Days to a Demo: Getting familiar with Jetson TX2”, to detect dogs, pedestrians, faces.
I modified the config file, and specified the trained detectnet prototxt and caffemodel. I see segfaults and core dumps.
Any suggestions on changing the Deepstream configuration in this simple way?
What’s did you modify?
Can’t you give the error log ?
ChrisDing: Thanks for responding.
Here’s the modified simplified config.txt file. The error log is also provided below. Your comments welcome. Thanks.
[application]
enable-perf-measurement=0
roi-marking=1
app-mode=0
[source0]
enable=1
#Type - 1=CameraCSi 2=CameraV4L2 3=URI
type=3
uri=file:///home/nvidia/sample_720p.mp4
[sink0]
enable=1
#Type - 1=FakeSink 2=OverlaySink 3=EglSink 4=XvImageSink 5=File
type=3
display-id=0
offset-x=0
offset-y=0
width=0
height=0
sync=1
#overlay-index=1
source-id=0
[osd]
enable=0
osd-mode=2
border-width=3
text-size=10
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
[primary-gie]
enable=1
net-scale-factor=0.0039215697906911373
model-file=file:///home/nvidia/Model/detect-facenet-120/snapshot_iter_24000.caffemodel
proto-file=file:///home/nvidia/Model/detect-facenet-120/deploy.prototxt
model-cache=file:///home/nvidia/Model/detect-facenet-120/face.caffemodel_b2_fp16.cache
net-stride=16
batch-size=2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;1;1;1
bbox-border-color3=0;1;0;1
#num-classes=4
#class-thresholds=0.2;0.2;0.2;0.2
#class-eps=0.1;0.1;0.1;0.1
#class-group-thresholds=3;3;3;3
color-format=0
roi-top-offset=0;0;0;0
roi-bottom-offset=0;0;0;0
detected-min-w=0;0;0;0
detected-min-h=0;0;0;0
detected-max-w=1920;100;1920;1920
detected-max-h=1080;1080;1080;1080
interval=1
-2 for all; -1 for none;
To set multiple class id’s use format as “1;2;0”
detect-color-class-ids=0;
gie-unique-id=1
parse-func=4
#is-classifier=0
output-bbox-name=Layer11_bbox
output-blob-names=Layer11_cov
Uncomment below lines for DBSCAN. EPS and minBoxes can be tuned for DBSCAN
#enable-dbscan=1
#class-minBoxes=4;4;4;4
#class-eps=0.7;0.7;0.7;0.7
Bit 0: Model decryption required
crypto-flags=0
[tests]
file-loop-count=0
#0=send overlaps; 1=do not send overlaps
server-overlap-mode=1
#Fixed to 1 for diplay color in GUI mode
color-mode=1
Error Log, when running nvgstiva-app -c config.txt
Using winsys: x11
Deploy Name : /home/nvidia/Model/detect-facenet-120/deploy.prototxt
Model Name : /home/nvidia/Model/detect-facenet-120/snapshot_iter_24000.caffemodel
Model Cache Name : /home/nvidia/Model/detect-facenet-120/face.caffemodel_b2_fp16.cache
Batch_Size 2
Error. Could not open model cache file /home/nvidia/Model/detect-facenet-120/face.caffemodel_b2_fp16.cache
Generating new GIE model cache
forced_fp32 has been set to 0(using fp16)
What’s your detectnet output layer? Is it as below?
This was indeed the problem with the file. After changing these parameters to the correct values, the crash is gone.
Thanks very much!
