• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.3
• TensorRT Version 8.4
• NVIDIA GPU Driver Version (valid for GPU only) 10.2
• Issue Type( questions, new requirements, bugs) - the issue is that pipeline is not link correctly when doing smart record event.
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) actually this is for pipeline bugs
Error occuring :
jetson@ubuntu:~/Documents/deepstream-testsr-app$ ./deepstream-testsr-app “rtsp://admin:Sieora123@192.168.1.108:554/cam/realmonitor?channel=3&subtype=0” --enc-type=1 --sink-type=1 --bbox-enable=1 --sr-mode=1
Hello
Now playing: rtsp://admin:Sieora123@192.168.1.108:554/cam/realmonitor?channel=3&subtype=0
Opening in BLOCKING MODE
0:00:10.325195570 11567 0x5581f0c260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/jetson/Documents/deepstream-testsr-app/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:10.326747306 11567 0x5581f0c260 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/jetson/Documents/deepstream-testsr-app/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
0:00:10.360413816 11567 0x5581f0c260 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstestsr_pgie_config.txt sucessfully
Running…
Recording started…
In cb_newpad
Failed to link depay loader to rtsp srcERROR from element udpsrc0: Internal data stream error.
Error details: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:dstest-sr-pipeline/GstRTSPSrc:rtsp-source/GstUDPSrc:udpsrc0:
streaming stopped, reason not-linked (-1)
** ERROR: RunUserCallback:207: No video stream found
Returned, stopping playback
Deleting pipeline
this is my compilation file
CUDA_VER?=10.2
ifeq ($(CUDA_VER),)
$(error “CUDA_VER is not set”)
endif
APP:= deepstream-testsr-app
TARGET_DEVICE = $(shell gcc -dumpmachine | cut -f1 -d -)
NVDS_VERSION:=6.0
LIB_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/lib/
APP_INSTALL_DIR?=/opt/nvidia/deepstream/deepstream-$(NVDS_VERSION)/bin/
ifeq ($(TARGET_DEVICE),aarch64)
CFLAGS:= -DPLATFORM_TEGRA
endif
SRCS:= $(wildcard *.c)
INCS:= $(wildcard *.h)
PKGS:= gstreamer-1.0
OBJS:= $(SRCS:.c=.o)
CFLAGS+= -I…/…/…/includes \
-I /usr/local/cuda-$(CUDA_VER)/include\
-I /home/jetson/Documents/deepstream-testsr-app/include\
-I /home/jetson/Documents/deepstream-testsr-app/includes
CFLAGS+= pkg-config --cflags $(PKGS)
LIBS:= pkg-config --libs $(PKGS)
LIBS+= -L$(LIB_INSTALL_DIR) -lnvdsgst_meta -lnvds_meta -lnvdsgst_helper -lnvdsgst_smartrecord \
-L/usr/local/cuda-$(CUDA_VER)/lib64/ -lcudart \
-lcuda -Wl,-rpath,$(LIB_INSTALL_DIR)
all: $(APP)
%.o: %.c $(INCS) Makefile
$(CC) -c -o $@ $(CFLAGS) $<
$(APP): $(OBJS) Makefile
$(CC) -o $(APP) $(OBJS) $(LIBS)
install: $(APP)
cp -rv $(APP) $(APP_INSTALL_DIR)
clean:
rm -rf $(OBJS) $(APP)
this is a configuration file :
property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file = Primary_Detector/resnet10.caffemodel
proto-file = Primary_Detector/resnet10.prototxt
model-engine-file = Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
labelfile-path = Primary_Detector/labels.txt
int8-calib-file = Primary_Detector/cal_trt.bin
force-implicit-batch-dim = 1
batch-size=1
#width=1920
#height=1080
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
#scaling-filter=0
#scaling-compute-hw=0
cluster-mode=2
[class-attrs-all]
pre-cluster-threshold=0.2
topk=20
nms-iou-threshold=0.5
#[class-attrs-0]
#pre-cluster-threshold=0.05
#eps=0.7
#dbscan-min-score=0.95
#[class-attrs-1]
#eps=0.7
#dbscan-min-score=0.5
#[class-attrs-2]
#pre-cluster-threshold=0.1
#eps=0.6
#[class-attrs-3]
#eps=0.7
this is a code for smart record:
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <string.h>
#include <cuda_runtime_api.h>
#include “gst-nvdssr.h”
GST_DEBUG_CATEGORY (NVDS_APP);
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
- different resolution. The muxer will scale all the input frames to this
- resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
- based on the fastest source’s framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
/* By default, OSD process-mode is set to CPU_MODE. To change mode, set as:
- 1: GPU mode (for Tesla only)
- 2: HW mode (For Jetson only)
#define OSD_PROCESS_MODE 0
/* By default, OSD will not display text. To display text, change this to 1 */
#define OSD_DISPLAY_TEXT 0
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { “Vehicle”, “TwoWheeler”, “Person”,
“Roadsign”
/* Config file parameters used for recording
- User needs to change these parameters to reflect the change in recordings
- e.g duration, start-time etc. */
/* Container format of recorded file 0 for mp4 and 1 for mkv format
#define SMART_REC_CONTAINER 0
/* Cache functionality of recording
#define CACHE_SIZE_SEC 15
/* Timeout if duration of recording is not set by user
#define SMART_REC_DEFAULT_DURATION 10
/* Time at which it recording is started
#define START_TIME 2
/* Duration of recording
#define SMART_REC_DURATION 7
/* Interval in seconds for
- SR start / stop events generation.
#define SMART_REC_INTERVAL 7
static gboolean bbox_enabled = TRUE;
static gint enc_type = 0; // Default: Hardware encoder
static gint sink_type = 2; // Default: Eglsink
static guint sr_mode = 0; // Default: Audio + Video
GOptionEntry entries = {
{“bbox-enable”, ‘e’, 0, G_OPTION_ARG_INT, &bbox_enabled,
“0: Disable bboxes,
1: Enable bboxes,
Default: bboxes enabled”, NULL}
{“enc-type”, ‘c’, 0, G_OPTION_ARG_INT, &enc_type,
“0: Hardware encoder,
1: Software encoder,
Default: Hardware encoder”, NULL}
{“sink-type”, ‘s’, 0, G_OPTION_ARG_INT, &sink_type,
“1: Fakesink,
2: Eglsink,
3: RTSP sink,
Default: Eglsink”, NULL}
{“sr-mode”, ‘m’, 0, G_OPTION_ARG_INT, &sr_mode,
“SR mode: 0 = Audio + Video,
1 = Video only,
2 = Audio only”, NULL}
{NULL}
static GstElement *pipeline = NULL, *tee_pre_decode = NULL;
static NvDsSRContext *nvdssrCtx = NULL;
static GMainLoop *loop = NULL;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print (“End of stream\n”);
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:{
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr (“ERROR from element %s: %s\n”,
GST_OBJECT_NAME (msg->src), error->message);
if (debug)
g_printerr (“Error details: %s\n”, debug);
g_free (debug);
g_error_free (error);
break;
default:
break;
return TRUE;
static gpointer
smart_record_callback (NvDsSRRecordingInfo * info, gpointer userData)
static GMutex mutex;
FILE *logfile = NULL;
g_return_val_if_fail (info, NULL);
g_mutex_lock (&mutex);
logfile = fopen (“smart_record.log”, “a”);
if (logfile) {
fprintf (logfile, “%d:%s:%d:%d:%s:%d channel(s):%d Hz:%ldms:%s:%s\n”,
info->sessionId, info->containsVideo ? “video” : “no-video”,
info->width, info->height, info->containsAudio ? “audio” : “no-audio”,
info->channels, info->samplingRate, info->duration,
info->dirpath, info->filename);
fclose (logfile);
} else {
g_print (“Error in opeing smart record log file\n”);
g_mutex_unlock (&mutex);
return NULL;
static gboolean
smart_record_event_generator (gpointer data)
NvDsSRSessionId sessId = 0;
NvDsSRContext *ctx = (NvDsSRContext *) data;
guint startTime = START_TIME;
guint duration = SMART_REC_DURATION;
if (ctx->recordOn) {
g_print (“Recording done.\n”);
if (NvDsSRStop (ctx, 0) != NVDSSR_STATUS_OK)
g_printerr (“Unable to stop recording\n”);
} else {
g_print (“Recording started…\n”);
if (NvDsSRStart (ctx, &sessId, startTime, duration,
NULL) != NVDSSR_STATUS_OK)
g_printerr (“Unable to start recording\n”);
return TRUE;
static void
cb_newpad_audio_parsebin (GstElement * element, GstPad * element_src_pad, gpointer data)
GstPad *sinkpad = gst_element_get_static_pad(nvdssrCtx->recordbin, “asink”);
if (gst_pad_link(element_src_pad, sinkpad) != GST_PAD_LINK_OK) {
g_print (“Elements not linked. Exiting. \n”);
g_main_loop_quit(loop);
static void
cb_newpad (GstElement * element, GstPad * element_src_pad, gpointer data)
g_print (“In cb_newpad\n”);
GstCaps *caps = gst_pad_get_current_caps (element_src_pad);
const GstStructure *str = gst_caps_get_structure (caps, 0);
const gchar *name = gst_structure_get_name (str);
GstElement *depay_elem = (GstElement *) data;
const gchar *media = gst_structure_get_string (str, “media”);
gboolean is_video = (!g_strcmp0 (media, “video”));
gboolean is_audio = (!g_strcmp0 (media, “audio”));
if (g_strrstr (name, “x-rtp”) && is_video) {
GstPad *sinkpad = gst_element_get_static_pad (depay_elem, “sink”);
if (gst_pad_link (element_src_pad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr (“Failed to link depay loader to rtsp src”);
gst_object_unref (sinkpad);
if (!bbox_enabled && (sr_mode == 0 || sr_mode == 1)) {
GstElement *parser_pre_recordbin =
gst_element_factory_make ("h264parse", "parser-pre-recordbin");
gst_bin_add_many (GST_BIN (pipeline), parser_pre_recordbin, NULL);
if (!gst_element_link_many (tee_pre_decode, parser_pre_recordbin,
nvdssrCtx->recordbin, NULL)) {
g_print ("Elements not linked. Exiting. \n");
gst_element_sync_state_with_parent(parser_pre_recordbin);
if (g_strrstr (name, “x-rtp”) && is_audio) {
if (!bbox_enabled && (sr_mode == 0 || sr_mode == 2)) {
gst_element_factory_make (“parsebin”, “audio-parser-pre-recordbin”);
GstPad *sinkpad = gst_element_get_static_pad(parser_pre_recordbin, "sink");
g_signal_connect(G_OBJECT(parser_pre_recordbin), "pad-added", G_CALLBACK(cb_newpad_audio_parsebin), NULL);
gst_caps_unref (caps);
int
main (int argc, char *argv)
GstElement *streammux = NULL, *sink = NULL, *pgie = NULL, *source = NULL,
*nvvidconv = NULL, *nvvidconv2 = NULL, *encoder_post_osd = NULL,
*queue_pre_sink = NULL, *queue_post_osd = NULL, *parser_post_osd = NULL,
*nvosd = NULL, *tee_post_osd = NULL, *queue_pre_decode = NULL,
*depay_pre_decode = NULL, *decoder = NULL, *nvvidconv3 = NULL,
*swenc_caps = NULL;
g_print(“Hello \n”);
GstCaps *caps = NULL;
GstElement *cap_filter = NULL;
GstBus *bus = NULL;
guint bus_watch_id = 0;
guint i = 0, num_sources = 1;
guint pgie_batch_size = 0;
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
GstElement *transform = NULL;
GOptionContext *gctx = NULL;
GOptionGroup *group = NULL;
GError *error = NULL;
NvDsSRInitParams params = { 0 };
gctx = g_option_context_new (“Nvidia DeepStream Test-SR app”);
group = g_option_group_new (“SR_test”, NULL, NULL, NULL, NULL);
g_option_group_add_entries (group, entries);
g_option_context_set_main_group (gctx, group);
g_option_context_add_group (gctx, gst_init_get_option_group ());
GST_DEBUG_CATEGORY_INIT (NVDS_APP, “NVDS_APP”, 0, NULL);
if (!g_option_context_parse (gctx, &argc, &argv, &error)) {
g_printerr (“%s”, error->message);
g_print (“%s”, g_option_context_get_help (gctx, TRUE, NULL));
return -1;
/* Check input arguments */
if (argc < 2) {
g_printerr (“Usage: %s <rtsp_h264 uri>\n”, argv[0]);
return -1;
if (argc > 2) {
g_printerr (“One rtsp_h264 uri supported Usage: %s <rtsp_h264 uri> \n”,
argv[0]);
return -1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements /
/ Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new (“dstest-sr-pipeline”);
source = gst_element_factory_make (“rtspsrc”, “rtsp-source”);
g_object_set (G_OBJECT (source), “location”, argv[1], NULL);
depay_pre_decode = gst_element_factory_make (“rtph264depay”, “h264-depay”);
queue_pre_decode = gst_element_factory_make (“queue”, “queue-pre-decode”);
if (!source || !depay_pre_decode || !queue_pre_decode) {
g_printerr (“One element in source end could not be created.\n”);
return -1;
g_signal_connect (G_OBJECT (source), “pad-added”,
G_CALLBACK (cb_newpad), depay_pre_decode);
/* Create tee which connects decoded source data and Smart record bin without bbox */
tee_pre_decode = gst_element_factory_make (“tee”, “tee-pre-decode”);
decoder = gst_element_factory_make (“nvv4l2decoder”, “nvv4l2-decoder”);
streammux = gst_element_factory_make (“nvstreammux”, “stream-muxer”);
/* Use nvinfer to infer on batched frame. */
pgie = gst_element_factory_make (“nvinfer”, “primary-nvinference-engine”);
/* Use queue to connect to the sink after tee_post_osd element */
queue_pre_sink = gst_element_factory_make (“queue”, “queue-pre-sink”);
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make (“nvvideoconvert”, “nvvideo-converter”);
/* Use convertor to convert from RGBA to CAPS filter data format */
nvvidconv2 =
gst_element_factory_make (“nvvideoconvert”, “nvvideo-converter2”);
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make (“nvdsosd”, “nv-onscreendisplay”);
/* Create tee which connects to sink and Smart record bin with bbox */
tee_post_osd = gst_element_factory_make (“tee”, “tee-post-osd”);
/* Finally render the osd output */
if(prop.integrated) {
transform = gst_element_factory_make (“nvegltransform”, “nvegl-transform”);
if (!transform) {
g_printerr (“One tegra element could not be created. Exiting.\n”);
return -1;
if (sink_type == 1) {
sink = gst_element_factory_make (“fakesink”, “nvvideo-renderer”);
else if (sink_type == 2) {
sink = gst_element_factory_make (“nveglglessink”, “nvvideo-renderer”);
g_object_set (G_OBJECT (sink), “async”, FALSE, NULL);
else if (sink_type == 3) {
sink = gst_element_factory_make (“nvrtspoutsinkbin”, “nvvideo-renderer”);
g_object_set (G_OBJECT (sink), “sync”, TRUE, NULL);
g_object_set (G_OBJECT (sink), “bitrate”, 768000, NULL);
g_object_set (G_OBJECT (sink), “enc-type”, 1, NULL);
g_object_set (G_OBJECT (streammux), “live-source”, 1, NULL);
caps = gst_caps_from_string (“video/x-raw(memory:NVMM), format=(string)I420”);
cap_filter =
gst_element_factory_make (“capsfilter”, “src_cap_filter_nvvidconv”);
g_object_set (G_OBJECT (cap_filter), “caps”, caps, NULL);
if (!pgie || !nvvidconv || !nvosd || !nvvidconv2 || !cap_filter
|| !tee_post_osd || !tee_pre_decode || !sink) {
g_printerr (“One element could not be created. Exiting.\n”);
return -1;
g_object_set (G_OBJECT (streammux), “batch-size”, num_sources, NULL);
g_object_set (G_OBJECT (streammux), “width”, MUXER_OUTPUT_WIDTH, “height”,
MUXER_OUTPUT_HEIGHT,
“batched-push-timeout”, MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (pgie),
“config-file-path”, “dstestsr_pgie_config.txt”, NULL);
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (pgie), “batch-size”, &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
(“WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n”,
pgie_batch_size, num_sources);
g_object_set (G_OBJECT (pgie), “batch-size”, num_sources, NULL);
g_object_set (G_OBJECT (nvosd), “process-mode”, OSD_PROCESS_MODE,
“display-text”, OSD_DISPLAY_TEXT, NULL);
g_object_set (G_OBJECT (sink), “qos”, 0, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline
- rtsp-source-> h264-depay → tee-> queue → decoder ->nvstreammux → nvinfer → nvvidconv → nvosd → nvvidconv → caps_filter → tee → queue → video-renderer
|-> queue -> encoder -> parser -> recordbin
gst_bin_add_many (GST_BIN (pipeline), source, depay_pre_decode,
tee_pre_decode, queue_pre_decode, decoder, streammux, pgie, nvvidconv,
nvosd, nvvidconv2, cap_filter, tee_post_osd, queue_pre_sink, sink, NULL);
gst_bin_add (GST_BIN (pipeline), transform);
/* Link the elements together till decoder */
if (!gst_element_link_many (depay_pre_decode, tee_pre_decode,
queue_pre_decode, decoder, NULL)) {
g_printerr (“Elements could not be linked: 1. Exiting.\n”);
return -1;
/* Link decoder with streammux */
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = “sink_0”;
gchar pad_name_src[16] = “src”;
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
if (!sinkpad) {
g_printerr (“Streammux request sink pad failed. Exiting.\n”);
return -1;
srcpad = gst_element_get_static_pad (decoder, pad_name_src);
if (!srcpad) {
g_printerr (“Decoder request src pad failed. Exiting.\n”);
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr (“Failed to link decoder to stream muxer. Exiting.\n”);
return -1;
gst_object_unref (srcpad);
/* Link the remaining elements of the pipeline to streammux */
if (!gst_element_link_many (streammux, pgie,
nvvidconv, nvosd, nvvidconv2, cap_filter, tee_post_osd,
queue_pre_sink, transform, sink, NULL)) {
g_printerr (“Elements could not be linked. Exiting.\n”);
return -1;
} else {
queue_pre_sink, sink, NULL)) {
return -1;
/* Parameters are set before creating record bin
- User can set additional parameters e.g recorded file path etc.
- Refer NvDsSRInitParams structure for additional parameters
params.containerType = SMART_REC_CONTAINER;
params.cacheSize = CACHE_SIZE_SEC;
params.defaultDuration = SMART_REC_DEFAULT_DURATION;
params.callback = smart_record_callback;
params.fileNamePrefix = bbox_enabled ? “With_BBox” : “Without_BBox”;
if (NvDsSRCreate (&nvdssrCtx, ¶ms) != NVDSSR_STATUS_OK) {
g_printerr (“Failed to create smart record bin”);
return -1;
gst_bin_add_many (GST_BIN (pipeline), nvdssrCtx->recordbin, NULL);
if (bbox_enabled) {
/* Encode the data from tee before recording with bbox /
if (enc_type == 0) {
/ Hardware encoder used*/
encoder_post_osd =
gst_element_factory_make (“nvv4l2h264enc”, “encoder-post-osd”);
} else if (enc_type == 1) {
/* Software encoder used*/
swenc_caps = gst_element_factory_make ("capsfilter", NULL);
GstCaps *enc_caps = NULL;
enc_caps = gst_caps_from_string ("video/x-h264, profile=(string)baseline");
g_object_set (G_OBJECT (swenc_caps), "caps", enc_caps, NULL);
gst_caps_unref (enc_caps);
encoder_post_osd =
gst_element_factory_make ("x264enc", "encoder-post-osd");
nvvidconv3 = gst_element_factory_make ("nvvideoconvert", "nvvidconv3");
gst_bin_add_many (GST_BIN (pipeline), swenc_caps, nvvidconv3, NULL);
/* Parse the encoded data after osd component */
parser_post_osd = gst_element_factory_make ("h264parse", "parser-post-osd");
/* Use queue to connect the tee_post_osd to nvencoder */
queue_post_osd = gst_element_factory_make ("queue", "queue-post-osd");
gst_bin_add_many (GST_BIN (pipeline), queue_post_osd, encoder_post_osd,
parser_post_osd, NULL);
if (!gst_element_link_many (tee_post_osd, queue_post_osd, encoder_post_osd,
parser_post_osd, nvdssrCtx->recordbin, NULL)) {
return -1;
/* Link swenc_caps and nvvidconv3 in case of software encoder*/
if (!gst_element_link_many (tee_post_osd, nvvidconv3, queue_post_osd,
encoder_post_osd, swenc_caps, parser_post_osd,
return -1;
if (nvdssrCtx) {
g_timeout_add (SMART_REC_INTERVAL * 1000, smart_record_event_generator,
nvdssrCtx);
/* Set the pipeline to “playing” state */
g_print (“Now playing:”);
g_print (" %s", argv[i + 1]);
g_print (“\n”);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS /
g_print (“Running…\n”);
g_main_loop_run (loop);
if (pipeline && nvdssrCtx) {
if(NvDsSRDestroy (nvdssrCtx) != NVDSSR_STATUS_OK)
g_printerr (“Unable to destroy recording instance\n”);
/ Out of the main loop, clean up nicely */
g_print (“Returned, stopping playback\n”);
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print (“Deleting pipeline\n”);
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
