Hello!
Unfortunately this - not yet solved - post somehow went out of Your „radar“ but is of great importance for us.
In short:
When trying to convert ONNX file into TensorRT engine file on Jetson Nano an error occured and you suggested that I try with newest TRT ver. 8.6.1 but:
Q1) Does for this 8.6.1 still apply the rule that the engine must be built on same machine type where inference will be run (Nano in this case) ?
Q2) If above answer is yes: TRT 8.6.1 is incompatible with Nano AFAIK, how to run in there then, in Docker perhaps?
Q3) If above answer is yes: could You please suggest Docker image for TRT 8.6.1 ? And must Nano be the host or host is other machine and Nano L4T is the container?
Environment
TensorRT Version: 8.0.1
GPU Type: Jetson Nano devkit (Maxwell)
Nvidia Driver Version:
CUDA Version: 10.2.300
CUDNN Version: 8.2.1
Operating System + Version: Ubuntu 18.04 (Jetpack 4.6.0)
PyTorch Version (if applicable): 1.12.1
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
