thanks and sorry about the lack of detail, my brain was mush already.
Wed May 31 04:53:19 2023
| NVIDIA-SMI 535.98 Driver Version: 535.98 CUDA Version: 12.2 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA RTX A5500 WDDM | 00000000:18:00.0 Off | Off |
| 30% 27C P8 5W / 230W | 0MiB / 24564MiB | 0% Default |
| | | N/A |
| 1 NVIDIA RTX A5500 WDDM | 00000000:3B:00.0 Off | Off |
| 30% 29C P8 7W / 230W | 0MiB / 24564MiB | 0% Default |
| | | N/A |
| 2 NVIDIA RTX A5500 WDDM | 00000000:D8:00.0 On | Off |
| 30% 32C P8 15W / 230W | 855MiB / 24564MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 2 N/A N/A 3108 C+G …5n1h2txyewy\ShellExperienceHost.exe N/A |
| 2 N/A N/A 14456 C+G C:\Windows\explorer.exe N/A |
| 2 N/A N/A 14832 C+G …1.0_x64__8wekyb3d8bbwe\Video.UI.exe N/A |
| 2 N/A N/A 16644 C+G …2txyewy\StartMenuExperienceHost.exe N/A |
| 2 N/A N/A 16788 C+G …0_x64__8wekyb3d8bbwe\HxOutlook.exe N/A |
| 2 N/A N/A 17264 C+G …Search_cw5n1h2txyewy\SearchApp.exe N/A |
| 2 N/A N/A 17928 C+G …b3d8bbwe\Microsoft.Media.Player.exe N/A |
| 2 N/A N/A 19708 C+G …CBS_cw5n1h2txyewy\TextInputHost.exe N/A |
| 2 N/A N/A 29920 C+G …_8wekyb3d8bbwe\Microsoft.Photos.exe N/A |
| 2 N/A N/A 32484 C+G …siveControlPanel\SystemSettings.exe N/A |
| 2 N/A N/A 32684 C+G …Search_cw5n1h2txyewy\SearchApp.exe N/A |
| 2 N/A N/A 36888 C+G …t.LockApp_cw5n1h2txyewy\LockApp.exe N/A
I have a windows 10 running
Intel(R) Xeon(R) Platinum 8280 CPU @ 2.70GHz 2.69 GHz (2 processors)
64-bit operating system, x64-based processor
Nvidia specs
535.98-quadro-rtx-desktop-notebook-win10-win11-64bit-international-dch-whql
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.8\cudnn-windows-x86_64-8.9.0.131_cuda11-archive
i believe running cuda11.8
NVIDIA_Nsight_Perf_SDK_2023.1_Public_Windows
i am using pytorch for model inference and from the pytorch tutorial, using cpp, the file that i am trying to run is torchscript: ts-infer.cpp via vs code, msvs code and i try to execute the command via windows command prompt.
toml 0.10.2
tomli 2.0.1
toolz 0.12.0
torch 2.0.0
torch-model-archiver 0.7.1b20230501
torch-model-archiver-nightly 2023.5.3
torch-package 1.0.1
torch-utils 0.1.2
torch-workflow-archiver 0.2.7b20230430
torch-workflow-archiver-nightly 2023.5.3
torchaudio 2.0.1
torchdata 0.6.0
torchinfo 1.7.2
torchlib 0.1
torchpippy 0.1.0
torchserve 0.7.1
torchserve-nightly 2023.5.3
torchtext 0.15.1
torchutils 0.0.4
torchvision 0.15.1
pytorch-gpu 0.0.1
pytorch-utils 0.5.5
and here
(base) C:\Users\rossroxas>python -m torch.utils.collect_env
C:\miniconda3\lib\site-packages\numpy_distributor_init.py:30: UserWarning: loaded more than 1 DLL from .libs:
C:\miniconda3\lib\site-packages\numpy.libs\libopenblas.QVLO2T66WEPI7JZ63PS3HMOHFEY472BC.gfortran-win_amd64.dll
C:\miniconda3\lib\site-packages\numpy.libs\libopenblas64__v0.3.21-gcc_10_3_0.dll
warnings.warn(“loaded more than 1 DLL from .libs:”
Collecting environment information…
PyTorch version: 2.0.0+cpu
Is debug build: False
CUDA used to build PyTorch: Could not collect
ROCM used to build PyTorch: N/A
OS: Microsoft Windows 10 Enterprise
GCC version: Could not collect
Clang version: Could not collect
CMake version: version 3.26.3
Libc version: N/A
Python version: 3.9.16 (main, Mar 8 2023, 10:39:24) [MSC v.1916 64 bit (AMD64)] (64-bit runtime)
Python platform: Windows-10-10.0.19045-SP0
Is CUDA available: False
CUDA runtime version: 11.8.89
CUDA_MODULE_LOADING set to: N/A
GPU models and configuration:
GPU 0: NVIDIA RTX A5500
GPU 1: NVIDIA RTX A5500
GPU 2: NVIDIA RTX A5500
Nvidia driver version: 535.98
cuDNN version: Could not collect
HIP runtime version: N/A
MIOpen runtime version: N/A
Is XNNPACK available: True
CPU:
Architecture=9
CurrentClockSpeed=2694
DeviceID=CPU0
Family=179
L2CacheSize=28672
L2CacheSpeed=
Manufacturer=GenuineIntel
MaxClockSpeed=2694
Name=Intel(R) Xeon(R) Platinum 8280 CPU @ 2.70GHz
ProcessorType=3
Revision=21767
Architecture=9
DeviceID=CPU1
Family=179
L2CacheSize=28672
L2CacheSpeed=
MaxClockSpeed=2694
ProcessorType=3
Revision=21767
Versions of relevant libraries:
[pip3] libtorch==1.2.0.1
[pip3] mypy==1.2.0
[pip3] mypy-extensions==1.0.0
[pip3] numpy==1.19.3
[pip3] pytorch-gpu==0.0.1
[pip3] pytorch-utils==0.5.5
[pip3] torch==2.0.0
[pip3] torch-model-archiver==0.7.1b20230501
[pip3] torch-model-archiver-nightly==2023.5.3
[pip3] torch-package==1.0.1
[pip3] torch-utils==0.1.2
[pip3] torch-workflow-archiver==0.2.7b20230430
[pip3] torch-workflow-archiver-nightly==2023.5.3
[pip3] torchaudio==2.0.1
[pip3] torchdata==0.6.0
[pip3] torchinfo==1.7.2
[pip3] torchlib==0.1
[pip3] torchpippy==0.1.0
[pip3] torchserve==0.7.1
[pip3] torchserve-nightly==2023.5.3
[pip3] torchtext==0.15.1
[pip3] torchutils==0.0.4
[pip3] torchvision==0.15.1
[conda] blas 1.0 mkl
[conda] cpuonly 1.0 0 pytorch
[conda] cudatoolkit 11.8.0 h09e9e62_11 conda-forge
[conda] libtorch 1.2.0.1 pypi_0 pypi
[conda] mkl 2020.2 256
[conda] mkl-include 2023.1.0 haa95532_46356
[conda] mkl-service 2.3.0 py39h196d8e1_0
[conda] mkl_fft 1.3.0 py39h46781fe_0
[conda] mkl_random 1.0.2 py39h848d8c7_0
[conda] numpy 1.24.0 pypi_0 pypi
[conda] pytorch-gpu 0.0.1 pypi_0 pypi
[conda] pytorch-utils 0.5.5 pypi_0 pypi
[conda] torch 2.0.0 pypi_0 pypi
[conda] torch-model-archiver 0.7.1b20230503 pypi_0 pypi
[conda] torch-model-archiver-nightly 2023.5.3 pypi_0 pypi
[conda] torch-package 1.0.1 pypi_0 pypi
[conda] torch-utils 0.1.2 pypi_0 pypi
[conda] torch-workflow-archiver 0.2.7b20230503 pypi_0 pypi
[conda] torch-workflow-archiver-nightly 2023.5.3 pypi_0 pypi
[conda] torchaudio 2.0.1 pypi_0 pypi
[conda] torchdata 0.6.0 pypi_0 pypi
[conda] torchinfo 1.7.2 pyhd8ed1ab_0 conda-forge
[conda] torchlib 0.1 pypi_0 pypi
[conda] torchpippy 0.1.0 pypi_0 pypi
[conda] torchserve 0.7.1 pypi_0 pypi
[conda] torchserve-nightly 2023.5.3 pypi_0 pypi
[conda] torchtext 0.15.1 pypi_0 pypi
[conda] torchutils 0.0.4 pypi_0 pypi
[conda] torchvision 0.15.1 pypi_0 pypi
let me know if i missed anything!
thanks!
