Using drivers 497.09:
Gettting a crash in driver :
nvoglv64.dll!00007ffe5b675c85() Unknown
nvoglv64.dll!00007ffe5b675166() Unknown
nvoglv64.dll!00007ffe5b6c747f() Unknown
nvoglv64.dll!00007ffe5b6bf1d0() Unknown
nvoglv64.dll!00007ffe5b6be210() Unknown
nvoglv64.dll!00007ffe5c7c08c1() Unknown
nvoglv64.dll!00007ffe5c7c0b83() Unknown
nvoglv64.dll!00007ffe5c7cca12() Unknown
nvoglv64.dll!00007ffe5c7cb648() Unknown
Full spir-v listing of the raygen shader:
OpCapability RayTracingKHR
OpCapability RuntimeDescriptorArray
OpCapability RayQueryKHR
OpCapability RayTraversalPrimitiveCullingKHR
OpExtension "SPV_KHR_ray_tracing"
OpExtension "SPV_EXT_descriptor_indexing"
OpExtension "SPV_KHR_ray_query"
%1 = OpExtInstImport "GLSL.std.450"
OpMemoryModel Logical GLSL450
OpEntryPoint RayGenerationNV %raygen_main "raygen_main" %g_rtas_table %g_views_table %g_constants %g_rw_textures %7 %8 %g_packed_views_table %g_render_constantsTable
OpSource HLSL 660
OpName %type_PushConstant_Constants "type.PushConstant.Constants"
OpMemberName %type_PushConstant_Constants 0 "v"
OpName %g_constants "g_constants"
OpName %type_2d_image "type.2d.image"
OpName %g_rw_textures "g_rw_textures"
OpName %type_StructuredBuffer_uint "type.StructuredBuffer.uint"
OpName %type_StructuredBuffer_View "type.StructuredBuffer.View"
OpName %View "View"
OpMemberName %View 0 "translation"
OpMemberName %View 1 "near"
OpMemberName %View 2 "rotation"
OpMemberName %View 3 "inv_translation"
OpMemberName %View 4 "inv_rotation"
OpMemberName %View 5 "view"
OpMemberName %View 6 "inv_view"
OpMemberName %View 7 "projection"
OpMemberName %View 8 "inv_projection"
OpMemberName %View 9 "view_projection"
OpMemberName %View 10 "inv_view_projection"
OpMemberName %View 11 "frustum"
OpName %g_views_table "g_views_table"
OpName %accelerationStructureNV "accelerationStructureNV"
OpName %g_rtas_table "g_rtas_table"
OpName %type_ConstantBuffer_RenderConstants "type.ConstantBuffer.RenderConstants"
OpMemberName %type_ConstantBuffer_RenderConstants 0 "min_shader_index"
OpMemberName %type_ConstantBuffer_RenderConstants 1 "shader_index_range"
OpMemberName %type_ConstantBuffer_RenderConstants 2 "shaders_total"
OpMemberName %type_ConstantBuffer_RenderConstants 3 "shaders_draw_counts_start"
OpMemberName %type_ConstantBuffer_RenderConstants 4 "shaders_instances_start"
OpMemberName %type_ConstantBuffer_RenderConstants 5 "shaders_draw_commands_start"
OpMemberName %type_ConstantBuffer_RenderConstants 6 "shaders_draw_parameters_start"
OpMemberName %type_ConstantBuffer_RenderConstants 7 "packed_mesh_instance_count"
OpMemberName %type_ConstantBuffer_RenderConstants 8 "packed_mesh_instances"
OpMemberName %type_ConstantBuffer_RenderConstants 9 "packed_view_count"
OpMemberName %type_ConstantBuffer_RenderConstants 10 "packed_views"
OpMemberName %type_ConstantBuffer_RenderConstants 11 "packed_mesh_shader_count"
OpMemberName %type_ConstantBuffer_RenderConstants 12 "packed_mesh_shaders"
OpMemberName %type_ConstantBuffer_RenderConstants 13 "packed_light_count"
OpMemberName %type_ConstantBuffer_RenderConstants 14 "packed_lights"
OpMemberName %type_ConstantBuffer_RenderConstants 15 "mesh_section_shader_index_channel"
OpMemberName %type_ConstantBuffer_RenderConstants 16 "mesh_shader_data_channel"
OpMemberName %type_ConstantBuffer_RenderConstants 17 "mesh_data"
OpMemberName %type_ConstantBuffer_RenderConstants 18 "ray_tracing_supported"
OpName %g_render_constantsTable "g_render_constantsTable"
OpName %g_packed_views_table "g_packed_views_table"
OpName %raygen_main "raygen_main"
OpName %rayQueryKHR "rayQueryKHR"
OpDecorate %8 BuiltIn LaunchIdNV
OpDecorate %7 BuiltIn LaunchSizeNV
OpDecorate %g_rw_textures DescriptorSet 2
OpDecorate %g_rw_textures Binding 0
OpDecorate %g_views_table DescriptorSet 6
OpDecorate %g_views_table Binding 0
OpDecorate %g_rtas_table DescriptorSet 7
OpDecorate %g_rtas_table Binding 0
OpDecorate %g_render_constantsTable DescriptorSet 5
OpDecorate %g_render_constantsTable Binding 0
OpDecorate %g_packed_views_table DescriptorSet 6
OpDecorate %g_packed_views_table Binding 0
OpDecorate %_arr_uint_uint_4 ArrayStride 4
OpMemberDecorate %type_PushConstant_Constants 0 Offset 0
OpDecorate %type_PushConstant_Constants Block
OpDecorate %_runtimearr_uint ArrayStride 4
OpMemberDecorate %type_StructuredBuffer_uint 0 Offset 0
OpMemberDecorate %type_StructuredBuffer_uint 0 NonWritable
OpDecorate %type_StructuredBuffer_uint Block
OpDecorate %_arr_v4float_uint_5 ArrayStride 16
OpMemberDecorate %View 0 Offset 0
OpMemberDecorate %View 1 Offset 12
OpMemberDecorate %View 2 Offset 16
OpMemberDecorate %View 3 Offset 32
OpMemberDecorate %View 4 Offset 44
OpMemberDecorate %View 5 Offset 60
OpMemberDecorate %View 5 MatrixStride 16
OpMemberDecorate %View 5 RowMajor
OpMemberDecorate %View 6 Offset 124
OpMemberDecorate %View 6 MatrixStride 16
OpMemberDecorate %View 6 RowMajor
OpMemberDecorate %View 7 Offset 188
OpMemberDecorate %View 7 MatrixStride 16
OpMemberDecorate %View 7 RowMajor
OpMemberDecorate %View 8 Offset 252
OpMemberDecorate %View 8 MatrixStride 16
OpMemberDecorate %View 8 RowMajor
OpMemberDecorate %View 9 Offset 316
OpMemberDecorate %View 9 MatrixStride 16
OpMemberDecorate %View 9 RowMajor
OpMemberDecorate %View 10 Offset 380
OpMemberDecorate %View 10 MatrixStride 16
OpMemberDecorate %View 10 RowMajor
OpMemberDecorate %View 11 Offset 444
OpDecorate %_runtimearr_View ArrayStride 524
OpMemberDecorate %type_StructuredBuffer_View 0 Offset 0
OpMemberDecorate %type_StructuredBuffer_View 0 NonWritable
OpDecorate %type_StructuredBuffer_View Block
OpMemberDecorate %type_ConstantBuffer_RenderConstants 0 Offset 0
OpMemberDecorate %type_ConstantBuffer_RenderConstants 1 Offset 4
OpMemberDecorate %type_ConstantBuffer_RenderConstants 2 Offset 8
OpMemberDecorate %type_ConstantBuffer_RenderConstants 3 Offset 12
OpMemberDecorate %type_ConstantBuffer_RenderConstants 4 Offset 16
OpMemberDecorate %type_ConstantBuffer_RenderConstants 5 Offset 20
OpMemberDecorate %type_ConstantBuffer_RenderConstants 6 Offset 24
OpMemberDecorate %type_ConstantBuffer_RenderConstants 7 Offset 28
OpMemberDecorate %type_ConstantBuffer_RenderConstants 8 Offset 32
OpMemberDecorate %type_ConstantBuffer_RenderConstants 9 Offset 36
OpMemberDecorate %type_ConstantBuffer_RenderConstants 10 Offset 40
OpMemberDecorate %type_ConstantBuffer_RenderConstants 11 Offset 44
OpMemberDecorate %type_ConstantBuffer_RenderConstants 12 Offset 48
OpMemberDecorate %type_ConstantBuffer_RenderConstants 13 Offset 52
OpMemberDecorate %type_ConstantBuffer_RenderConstants 14 Offset 56
OpMemberDecorate %type_ConstantBuffer_RenderConstants 15 Offset 60
OpMemberDecorate %type_ConstantBuffer_RenderConstants 16 Offset 64
OpMemberDecorate %type_ConstantBuffer_RenderConstants 17 Offset 68
OpMemberDecorate %type_ConstantBuffer_RenderConstants 18 Offset 72
OpDecorate %type_ConstantBuffer_RenderConstants Block
%uint = OpTypeInt 32 0
%uint_0 = OpConstant %uint 0
%uint_1 = OpConstant %uint 1
%float = OpTypeFloat 32
%uint_4 = OpConstant %uint 4
%uint_5 = OpConstant %uint 5
%v3float = OpTypeVector %float 3
%float_1 = OpConstant %float 1
%float_0 = OpConstant %float 0
%int = OpTypeInt 32 1
%int_0 = OpConstant %int 0
%int_10 = OpConstant %int 10
%int_2 = OpConstant %int 2
%float_0_5 = OpConstant %float 0.5
%v2float = OpTypeVector %float 2
%38 = OpConstantComposite %v2float %float_0_5 %float_0_5
%float_2 = OpConstant %float 2
%float_n2 = OpConstant %float -2
%41 = OpConstantComposite %v2float %float_2 %float_n2
%float_n1 = OpConstant %float -1
%43 = OpConstantComposite %v2float %float_n1 %float_1
%float_0_99000001 = OpConstant %float 0.99000001
%int_1 = OpConstant %int 1
%_arr_uint_uint_4 = OpTypeArray %uint %uint_4
%type_PushConstant_Constants = OpTypeStruct %_arr_uint_uint_4
%_ptr_PushConstant_type_PushConstant_Constants = OpTypePointer PushConstant %type_PushConstant_Constants
%type_2d_image = OpTypeImage %float 2D 2 0 0 2 Rgba32f
%_runtimearr_type_2d_image = OpTypeRuntimeArray %type_2d_image
%_ptr_UniformConstant__runtimearr_type_2d_image = OpTypePointer UniformConstant %_runtimearr_type_2d_image
%_runtimearr_uint = OpTypeRuntimeArray %uint
%type_StructuredBuffer_uint = OpTypeStruct %_runtimearr_uint
%_runtimearr_type_StructuredBuffer_uint = OpTypeRuntimeArray %type_StructuredBuffer_uint
%_ptr_StorageBuffer__runtimearr_type_StructuredBuffer_uint = OpTypePointer StorageBuffer %_runtimearr_type_StructuredBuffer_uint
%v4float = OpTypeVector %float 4
%mat4v4float = OpTypeMatrix %v4float 4
%_arr_v4float_uint_5 = OpTypeArray %v4float %uint_5
%View = OpTypeStruct %v3float %float %v4float %v3float %v4float %mat4v4float %mat4v4float %mat4v4float %mat4v4float %mat4v4float %mat4v4float %_arr_v4float_uint_5
%_runtimearr_View = OpTypeRuntimeArray %View
%type_StructuredBuffer_View = OpTypeStruct %_runtimearr_View
%_runtimearr_type_StructuredBuffer_View = OpTypeRuntimeArray %type_StructuredBuffer_View
%_ptr_StorageBuffer__runtimearr_type_StructuredBuffer_View = OpTypePointer StorageBuffer %_runtimearr_type_StructuredBuffer_View
%accelerationStructureNV = OpTypeAccelerationStructureKHR
%_runtimearr_accelerationStructureNV = OpTypeRuntimeArray %accelerationStructureNV
%_ptr_UniformConstant__runtimearr_accelerationStructureNV = OpTypePointer UniformConstant %_runtimearr_accelerationStructureNV
%type_ConstantBuffer_RenderConstants = OpTypeStruct %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint %uint
%_runtimearr_type_ConstantBuffer_RenderConstants = OpTypeRuntimeArray %type_ConstantBuffer_RenderConstants
%_ptr_Uniform__runtimearr_type_ConstantBuffer_RenderConstants = OpTypePointer Uniform %_runtimearr_type_ConstantBuffer_RenderConstants
%v3uint = OpTypeVector %uint 3
%_ptr_Input_v3uint = OpTypePointer Input %v3uint
%void = OpTypeVoid
%62 = OpTypeFunction %void
%v2uint = OpTypeVector %uint 2
%_ptr_Function_accelerationStructureNV = OpTypePointer Function %accelerationStructureNV
%_ptr_PushConstant_uint = OpTypePointer PushConstant %uint
%_ptr_Uniform_uint = OpTypePointer Uniform %uint
%_ptr_StorageBuffer_uint = OpTypePointer StorageBuffer %uint
%_ptr_StorageBuffer_View = OpTypePointer StorageBuffer %View
%_ptr_UniformConstant_accelerationStructureNV = OpTypePointer UniformConstant %accelerationStructureNV
%bool = OpTypeBool
%_ptr_UniformConstant_type_2d_image = OpTypePointer UniformConstant %type_2d_image
%rayQueryKHR = OpTypeRayQueryKHR
%_ptr_Function_rayQueryKHR = OpTypePointer Function %rayQueryKHR
%g_constants = OpVariable %_ptr_PushConstant_type_PushConstant_Constants PushConstant
%g_rw_textures = OpVariable %_ptr_UniformConstant__runtimearr_type_2d_image UniformConstant
%g_views_table = OpVariable %_ptr_StorageBuffer__runtimearr_type_StructuredBuffer_View StorageBuffer
%g_rtas_table = OpVariable %_ptr_UniformConstant__runtimearr_accelerationStructureNV UniformConstant
%g_render_constantsTable = OpVariable %_ptr_Uniform__runtimearr_type_ConstantBuffer_RenderConstants Uniform
%g_packed_views_table = OpVariable %_ptr_StorageBuffer__runtimearr_type_StructuredBuffer_uint StorageBuffer
%8 = OpVariable %_ptr_Input_v3uint Input
%7 = OpVariable %_ptr_Input_v3uint Input
%uint_645 = OpConstant %uint 645
%raygen_main = OpFunction %void None %62
%74 = OpLabel
%75 = OpVariable %_ptr_Function_rayQueryKHR Function
%76 = OpVariable %_ptr_Function_accelerationStructureNV Function
%77 = OpLoad %v3uint %8
%78 = OpVectorShuffle %v2uint %77 %77 0 1
%79 = OpAccessChain %_ptr_PushConstant_uint %g_constants %int_0 %int_2
%80 = OpLoad %uint %79
%81 = OpAccessChain %_ptr_PushConstant_uint %g_constants %int_0 %int_0
%82 = OpLoad %uint %81
%83 = OpAccessChain %_ptr_Uniform_uint %g_render_constantsTable %82 %int_10
%84 = OpLoad %uint %83
%85 = OpAccessChain %_ptr_StorageBuffer_uint %g_packed_views_table %84 %int_0 %80
%86 = OpLoad %uint %85
%87 = OpAccessChain %_ptr_StorageBuffer_View %g_views_table %uint_1 %int_0 %86
%88 = OpLoad %View %87
%89 = OpCompositeExtract %mat4v4float %88 6
%90 = OpCompositeExtract %mat4v4float %88 8
%91 = OpConvertUToF %v2float %78
%92 = OpFAdd %v2float %91 %38
%93 = OpLoad %v3uint %7
%94 = OpVectorShuffle %v2uint %93 %93 0 1
%95 = OpConvertUToF %v2float %94
%96 = OpFDiv %v2float %92 %95
%97 = OpFMul %v2float %96 %41
%98 = OpFAdd %v2float %97 %43
%99 = OpCompositeExtract %float %98 0
%100 = OpCompositeExtract %float %98 1
%101 = OpCompositeConstruct %v4float %99 %100 %float_1 %float_1
%102 = OpVectorTimesMatrix %v4float %101 %90
%103 = OpVectorShuffle %v3float %102 %102 0 1 2
%104 = OpCompositeExtract %float %102 3
%105 = OpCompositeConstruct %v3float %104 %104 %104
%106 = OpFDiv %v3float %103 %105
%107 = OpCompositeConstruct %v4float %99 %100 %float_0_99000001 %float_1
%108 = OpVectorTimesMatrix %v4float %107 %90
%109 = OpVectorShuffle %v3float %108 %108 0 1 2
%110 = OpCompositeExtract %float %108 3
%111 = OpCompositeConstruct %v3float %110 %110 %110
%112 = OpFDiv %v3float %109 %111
%113 = OpCompositeExtract %float %106 0
%114 = OpCompositeExtract %float %106 1
%115 = OpCompositeExtract %float %106 2
%116 = OpCompositeConstruct %v4float %113 %114 %115 %float_1
%117 = OpVectorTimesMatrix %v4float %116 %89
%118 = OpVectorShuffle %v3float %117 %117 0 1 2
%119 = OpCompositeExtract %float %112 0
%120 = OpCompositeExtract %float %112 1
%121 = OpCompositeExtract %float %112 2
%122 = OpCompositeConstruct %v4float %119 %120 %121 %float_1
%123 = OpVectorTimesMatrix %v4float %122 %89
%124 = OpVectorShuffle %v3float %123 %123 0 1 2
%125 = OpFSub %v3float %124 %118
%126 = OpExtInst %v3float %1 Normalize %125
%127 = OpAccessChain %_ptr_UniformConstant_accelerationStructureNV %g_rtas_table %uint_0
%128 = OpLoad %accelerationStructureNV %127
OpStore %76 %128
%129 = OpLoad %accelerationStructureNV %76
OpRayQueryInitializeKHR %75 %129 %uint_645 %uint_1 %118 %float_0 %126 %float_1
%130 = OpRayQueryProceedKHR %bool %75
%131 = OpRayQueryGetIntersectionTypeKHR %uint %75 %uint_1
%132 = OpIEqual %bool %131 %uint_1
%133 = OpSelect %float %132 %float_1 %float_0
%134 = OpCompositeConstruct %v4float %133 %133 %133 %133
%135 = OpAccessChain %_ptr_PushConstant_uint %g_constants %int_0 %int_1
%136 = OpLoad %uint %135
%137 = OpAccessChain %_ptr_UniformConstant_type_2d_image %g_rw_textures %136
%138 = OpLoad %type_2d_image %137
OpImageWrite %138 %78 %134 None
OpReturn
OpFunctionEnd
Same shader without ray queries (for comparison):
(does not crash)
OpEntryPoint RayGenerationNV %raygen_main "raygen_main" %3 %g_constants %5 %g_rw_textures
OpSource HLSL 660
OpDecorate %5 BuiltIn LaunchIdNV
OpDecorate %3 BuiltIn LaunchSizeNV
%17 = OpConstantComposite %v4float %float_0 %float_0 %float_0 %float_0
%void = OpTypeVoid
%25 = OpTypeFunction %void
%5 = OpVariable %_ptr_Input_v3uint Input
%3 = OpVariable %_ptr_Input_v3uint Input
%raygen_main = OpFunction %void None %25
%29 = OpLabel
%30 = OpLoad %v3uint %5
%31 = OpVectorShuffle %v2uint %30 %30 0 1
%32 = OpAccessChain %_ptr_PushConstant_uint %g_constants %int_0 %int_1
%33 = OpLoad %uint %32
%34 = OpAccessChain %_ptr_UniformConstant_type_2d_image %g_rw_textures %33
%35 = OpLoad %type_2d_image %34
OpImageWrite %35 %31 %17 None
OpReturn
OpFunctionEnd
