Hi mdegans
You’re right, with your command the process is starting and the menuconfig is shown.
I was able to select RAID support but after a few minutes I got the following error:
running: /home/marco/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/apply_binaries.sh -t -r /home/marco/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/rootfs
Using rootfs directory of: --
install: missing file operand
Try 'install --help' for more information.
File "/usr/local/bin/tegrity", line 11, in <module>
load_entry_point('tegrity==0.0.3', 'console_scripts', 'tegrity')()
File "/usr/local/lib/python3.6/dist-packages/tegrity/__main__.py", line 139, in cli_main
return build(**kwargs)
File "/usr/local/lib/python3.6/dist-packages/tegrity/__main__.py", line 69, in build
fix_sources=rootfs_source,
File "/usr/local/lib/python3.6/dist-packages/tegrity/rootfs.py", line 183, in main
apply_binaries(rootfs, target_overlay=target_overlay)
File "/usr/local/lib/python3.6/dist-packages/tegrity/rootfs.py", line 163, in apply_binaries
tegrity.utils.run(command, cwd=l4t_path).check_returncode()
File "/usr/lib/python3.6/subprocess.py", line 389, in check_returncode
self.stderr)
subprocess.CalledProcessError: Command '['/home/marco/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/apply_binaries.sh', '-t', '-r', '/home/marco/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3448/Linux_for_Tegra/rootfs']' returned non-zero exit status 1.
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 67, in apport_excepthook
binary = os.path.realpath(os.path.join(os.getcwd(), sys.argv[0]))
FileNotFoundError: [Errno 2] No such file or directory
Original exception was:
self.stderr)
Do you know how to proceed?
Many thanks & best regards!
