Problem:
I set up a new host VM with Ubuntu 16.04 using the current version SDK Manager (Version: 0.9.8.2002).
It looks like TensorRT and CuDNN (libs for cross compiling) are not getting installed on the host with this version. What am i doing wrong?
Dear emm7,
Did you select only Host side installation in SDKmanager? Also, Could you please delete cache (~/.nvsdkm folder) and try installing again and attach the following log files here.
~/.nvsdkm/sdkm.log
~/.nvsdkm/logs
Thanks. I set up a new clean VM and ran a full install (Host and Autochauffeur, skipping the flash step). I attached ~/.nvsdkm/sdkm.log, the (zipped) ~/.nvsdkm/logs directory and the exported logs from the sdk manager.
Dear emm7,
If the installation is successful you can find tensorRT at /usr/local/cuda-9.2/dl and /usr/local/cuda-9.2/dl/targets/aarch64-linux-gnu/lib contains the cross compiled libraries of TensorRT, cudnn. Could you check and confirm
