CSI Camera not working Jetson Orin Nano
Hello dear community, I recently bought a jetson orin nano. I try to open the csi camera that comes with but there is an error. I try NoIR camera, and rpi v1.3 camera and still cannot open the camera.
Here is my code:
#!/usr/bin/env python
# encoding: utf-8
import cv2 as cv
import time
capture = cv.VideoCapture("nvarguscamerasrc ! video/x-raw(memory:NVMM), width=1280, height=720, format=(string)NV12, framerate=(fraction)60/1 ! nvvidconv flip-method=0 ! video/x-raw, width=1280, height=720, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink", cv.CAP_GSTREAMER)
print ("capture get FPS : ",capture.get(cv.CAP_PROP_FPS))
while capture.isOpened():
    start = time.time()
    ret, frame = capture.read()
    if cv.waitKey(1) & 0xFF == ord('q'): break
    end = time.time()
    fps = 1 / (end - start)
    text="FPS : "+str(int(fps))
    cv.putText(frame, text, (20, 30), cv.FONT_HERSHEY_SIMPLEX, 0.9, (0, 0, 255), 1)
    cv.imshow('frame', frame)
capture.release()
cv.destroyAllWindows()
and here is the error I got:
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:751 No cameras available
[ WARN:0] global ../modules/videoio/src/cap_gstreamer.cpp (935) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
capture get FPS :  60.0
  File "test_camera_csi.py", line 17, in <module>
cv2.error: OpenCV(4.2.0) ../modules/highgui/src/window.cpp:376: error: (-215:Assertion failed) size.width>0 && size.height>0 in function 'imshow'
I am not sure if I have to install a driver for this camera. I ask for your help. Many thanks in advance.
hello alberto18_90,
there is error… No cameras available reported, which means the camera device did not register to system correctly.
Orin Nano support Raspberry pi v2, imx219 by default, you may running Jetson-IO to configure the CSI settings if you had dtbo files.
please see-also developer guide, Configuring the CSI Connector.
