Hmm there are still problems with the CUBLAS code in the previous post but it works for square matrix. However I made a mistake in comparing the timing, this code is for a 10 x 10 martix but I was comparing with my own, non-optimised CUDA code which was running a 100x100 matrix, and then performing a sigmoid function on the resulting vector. It turns out the CUBLAS implementation is actually slower than my own code, which can’t be right??? maybe I’m misunderstanding something…
I include my own version of matrix-vector multiplication (followed by sigmoid transformation as the basis of a neural network update).
Can someone verify my timing (adjust M & N to 100 in the CUBLAS version in the previous post)
Also verify the overall program execution time?
// incrementArray.cu
#include <stdio.h>
#include <assert.h>
#include <cuda.h>
void NN_OnHost(float *activity, float *weights, int N)
int i,j;
float new_activity[N];
for (i=0;i<N;i++) {
new_activity[i] = 0;
for(j=0;j<N;j++) {
new_activity[i] += activity[j] * weights[(j*N)+i];
for (i=0; i < N; i++) {
activity[i] = 1/(1+exp(-new_activity[i]));
__global__ void NN_OnDevice(float *activity, float *weights, float *new_activity, int N)
int j, idx = threadIdx.x;
new_activity[idx] = 0;
for(j=0;j<N;j++) {
new_activity[idx] += activity[j] * weights[(j*N)+idx];
__syncthreads();
activity[idx] = 1/(1+exp(-new_activity[idx]));
int main(void)
cudaSetDevice(0);
float *activity_h, *weights_h, *new_activity_h; // pointers to host memory
float *activity_d, *weights_d, *new_activity_d; // pointer to device memory
int i, j, N = 100;
size_t size = N*sizeof(float);
//timer stuff
cudaEvent_t start, stop;
cudaEventCreate(&start);
cudaEventCreate(&stop);
// allocate arrays on host
activity_h = (float *)malloc(size);
new_activity_h = (float *)malloc(size);
weights_h = (float *)malloc(size*size);
// allocate array on device
cudaMalloc((void **) &activity_d, size);
cudaMalloc((void **) &new_activity_d, size);
cudaMalloc((void **) &weights_d, size*size);
// initialization of host data
for (i=0; i<N; i++) {
activity_h[i] = (float(rand() % 100) / 100);
for(j=0; j<N; j++) {
weights_h[(j*N)+i] = (float(rand() % 200) / 100) - 1;
//printf("%f ",weights_h[(j*N)+i]);
//printf("%f ",activity_h[i]);
//printf("\n");
// copy data from host to device
cudaMemcpy(activity_d, activity_h, sizeof(float)*N, cudaMemcpyHostToDevice);
cudaMemcpy(weights_d, weights_h, sizeof(float)*N*N, cudaMemcpyHostToDevice);
// do calculation on host
NN_OnHost(activity_h, weights_h, N);
for (i=0; i<10; i++) printf("%f ",activity_h[i]);
printf("\n");
//start timer
cudaEventRecord(start, 0);
// do calculation on device:
NN_OnDevice <<< 1, N >>> (activity_d, weights_d, new_activity_d, N);
// block until the device has completed
cudaThreadSynchronize();
//end timer
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
float elapsedTime;
cudaEventElapsedTime(&elapsedTime, start, stop);
// Retrieve result from device and store in b_h
cudaMemcpy(new_activity_h, activity_d, sizeof(float)*N, cudaMemcpyDeviceToHost);
for (i=0; i<10; i++) printf("%f ",new_activity_h[i]);
printf("\n");
printf("time = %f\n\n",elapsedTime);
// cleanup
free(activity_h); free(weights_h); free(new_activity_h);
cudaFree(activity_d); cudaFree(weights_d); cudaFree(new_activity_d);
cudaEventDestroy(start);
cudaEventDestroy(stop);
I also have a partially optimised version using shared memory but the speed increase is not significant… yet…
