cublas solving a linear system
I have a 1-D array, say “x” with 441x1 elements. Now I have two more inputs - matrix “A(3x3)” and vector “b”(3x1) which are initialized apriori.
Now I need to solve Ax = b for different segmented values of “x” (of size 3x1) in parallel using cublas. All the variables, “A”, "b’ and “x” are of the double data type.
(ie) I would like to compute steps below in parallel:
A x(1 to 3) = b
A x(4 to 6) = b
A x(7 to 9) = b
Could you please suggest how this can be done using cublas calls?
Thanks,
Sreeram
This doesn’t make a lot of sense to me. If A and b are defined, why would you expect more than one solution of the linear system Ax=b ?
There is normally only one set of values for the vector x which will satisfy the linear system, barring degenerate cases.
Is there any particular reason this has to be done in cublas?
A similar problem that I have seen is solving Ax=b for a number of different b vectors:
Ax1 = b1
Ax2 = b2
Ax3 = b3
In this case, the solution vectors x1, x2, x3, may indeed be different. Such a problem/request would be sensible to me.
If you are looking for something like that, cusolver has a possible worked example. The example only covers a single b vector (so called “right hand side vector”, i.e. nrhs=1 in that example) but it should be trivial to extend it for the case where nrhs>1
http://docs.nvidia.com/cuda/cusolver/index.html#ormqr-example1
This use case does not look like a good fit for CUBLAS, or indeed GPUs. If I understand correctly, you are solving 147 different 3x3 systems, and what you call vector ‘x’ are actually 147 different right-hand sides ‘b’, and what you need to compute are 147 solution vectors ‘x’. Given how tiny the systems are, you should get best performance with a simple custom solver, with each thread solving a 3x3 system.
But the parallelism of this is way too since only 147 threads would be used, as a GPU needs on the order of 10,000 threads to reach full performance. So unless this computation is part of a bigger processing pipeline that has already been ported to the GPU, you would be better off running this on the CPU where this little data is easily stored in L1/L2 caches. Again, you would probably also want to use a custom solver rather than using a library such as MKL, as the library overhead would be substantial given the tiny matrices.
Hi all,
Thanks for your inputs. i have not correctly stated the problem. Apologies for that. Please see the problem I face below:
I have two input arrays in 1-D ===> 1) “A” of size 672841, 2)“b” of size 112141.
I need to solve in parallel:
A(1:36) x1 = b (1:6) and find x1 (of size 6*1)
A(37:73) x2 = b (7:12) and find x2 (of size 61)
A(67248:67284) x1869 = b(11208:11214) and find x1869(of size 6
1)
Could you please suggest how to solve this in parallel?
  1. There was a suggestion on writing a custom kernel. will that not be time consuming?
  2. Even if write a custom kernel, to find x1 = inverse(A1)b1 needs to be found. Then how to find the inverse of a 66 matrix?
  3. Will the batched solver help in this case? Could anyone please suggest.
So you basically want to solve:
A1x1=b1
A2x2=b2
A3x3=b3
in parallel.
There is a batched solver code available for download as a registered developer. I had difficulty finding it by navigation, but the direct link still seems to work:
https://developer.nvidia.com/rdp/assets/cuda-batched-solver-tgz
You’ll need to log in with your registered developer credentials before that link will work, I believe.
