After successfully trained the network and save it in a SavedModel format, TF Serving displays the fallowing error:
2021-05-11 13:41:27.083035: I tensorflow/cc/saved_model/loader.cc:277] SavedModel load for tags { serve }; Status: success: OK. Took 1886711 microseconds.
2021-05-11 13:41:27 (INFO) TensorflowModelServe: Source info :
2021-05-11 13:41:27 (INFO) TensorflowModelServe: Receptive field : [160, 160]
2021-05-11 13:41:27 (INFO) TensorflowModelServe: Placeholder name : lr_input
2021-05-11 13:41:27 (INFO) TensorflowModelServe: Output spacing ratio: 0.25
2021-05-11 13:41:27 (INFO) TensorflowModelServe: The TensorFlow model is used in fully convolutional mode
2021-05-11 13:41:27 (INFO) TensorflowModelServe: Output field of expression: [512, 512]
2021-05-11 13:41:27 (INFO) TensorflowModelServe: Tiling disabled
2021-05-11 13:41:27 (WARNING): Streaming configuration through extended filename is used. Any previous streaming configuration (ram value, streaming mode ...) will be ignored.
2021-05-11 13:41:27 (INFO): File Image_test.tif will be written in 110 blocks of 512x512 pixels
Writing Image_test.tif?&gdal:co:COMPRESS=DEFLATE&streaming:type=tiled&streaming:sizemode=height&streaming:sizevalue=512...: 0% [ ]2021-05-11 13:41:27.770868: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcudnn.so.8
2021-05-11 13:41:28.572215: I tensorflow/stream_executor/platform/default/dso_loader.cc:49] Successfully opened dynamic library libcublas.so.11
2021-05-11 13:41:28.573738: E tensorflow/stream_executor/cuda/cuda_blas.cc:226] failed to create cublas handle: CUBLAS_STATUS_NOT_INITIALIZED
2021-05-11 13:41:28.573882: W tensorflow/core/framework/op_kernel.cc:1763] OP_REQUIRES failed at conv_ops.cc:1106 : Not found: No algorithm worked!
Reading about it the solution to fix this is:
config = tf.ConfigProto()
config.gpu_options.allow_growth = True
sess = tf.Session(config=config)
but this solution conflicts with the code that I’m trying to run.
So the question is why is this error occurring in the first place?
TF 2.4.1, CUDA 11.3, CUDNN 8.2
