I have written a small test case that multiplies C=A’ * B using cublasDgemm. When the dimensions of A’ get large enough, entries of C hold incorrect values. Could someone please offer some help or advice?
Specifically, A is K x I, B is K x J, and C is I x J. My program sets entries of A to 0.2, entries of B to 1.0, so one would expect every entry of C to equal 0.2*K.
The results (indicating (I,J,K) and the outcome) are:
(10, 10, 8): OK.
(100, 100, 8): OK.
(300, 100, 8): OK.
(300, 1000, 8): OK.
(300, 10000, 8): Fail!
Difference at C position (0, 0)
Expected: 1.6
Found: 6.4
(10, 10, 8): OK.
(100, 100, 8): OK.
(300, 100, 8): OK.
(300, 1000, 8): OK.
Expected: 1.6
Found: 6.4
The program source and Makefile is attached here. [attachment=24609:cublas-bug.tar.gz]
My configuration is:
[dalexander@pearson cublas-bug]$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 260.19.12 Fri Oct 8 11:17:08 PDT 2010
GCC version: gcc version 4.4.3 20100127 (Red Hat 4.4.3-4) (GCC)
I updated to the final 3.2, and it still fails on my GTX 480. eelsen: what is your gcc version?
I have added tests for SGEMM as well. SGEMM seems to work fine:
[dalexander@pearson cublas-bug]$ ./test32
(10, 10, 8): OK.
(100, 100, 8): OK.
(300, 100, 8): OK.
(300, 1000, 8): OK.
(300, 10000, 8): OK.
while DGEMM still fails:
[dalexander@pearson cublas-bug]$ ./test64
(10, 10, 8): OK.
(100, 100, 8): OK.
(300, 100, 8): OK.
(300, 1000, 8): OK.
Expected: 1.6
Found: 6.4
(10, 10, 8): OK.
(100, 100, 8): OK.
(300, 100, 8): OK.
(300, 1000, 8): OK.
(10, 10, 8): OK.
(100, 100, 8): OK.
(300, 100, 8): OK.
(300, 1000, 8): OK.
Expected: 1.6
Found: 6.4
Could be related to the driver (260.19). There was an earlier post that certain integer64 operations were not working properly with CUDA 3.2. It was traced to a possible driver problem - 260.19. Slightly Earlier driver version did not have. Check it out.
I am satisfied that this is a bug in CUBLAS, perhaps having something to do with the configuration of my machine. Is there a more formal procedure for filing a bug?
