Hello, I wanted to create a prim and set new point values (8 points to make it a cuboid) to this prim, and I have being searching through the documentation but all I could find was the command omni.usd.commands.CreatePrimWithDefaultXformCommand . I guess I could pass the data on the attributes argument but there is no more info or examples on how to do it, and I have tried different formatting styles to create it but it doesn’t work.
Do you have any example available of what I’m trying to do? Or maybe I need other class to do it?
Im new to usd and Omniverse, so maybe the problem is that I don’t have clear what I’m working with. Any imput is appreciated.
Hi inessorzano,
Not sure if your point values exist inside a mesh, but if so the following may help you along:
from pxr import UsdGeom, Sdf, UsdGeom, Gf
import omni.usd
class UsdGeomMeshUtility:
@staticmethod
def CreatePrimWithCubeMesh(
primPath: str = "/World/newPrim",
size: Gf.Vec3f = (2.0, 2.0, 2.0),
position: Gf.Vec3f = (2.0, 2.0, 2.0),
rotationXYZ: Gf.Vec3f = (45.0, 45.0, 45.0)) -> UsdGeom.Xform:
"""Generate a Cube with size at postion and rotation"""
# get a reference to the active stage
x = size[0]
y = size[1]
z = size[2]
# create or get a prim at path /World/newPrim
targetPrim: UsdGeom.Xform = UsdGeom.Xform.Define(stage, Sdf.Path(primPath))
# position and rotate the prim
targetPrim.AddTranslateOp().Set(position)
targetPrim.AddRotateXYZOp().Set(rotationXYZ)
# create or get a mesh component on the prim
targetMesh: UsdGeom.Mesh = UsdGeom.Mesh.Define(stage, primPath)
# create an array with identity cube coordinates (position verts at size), and assign to points
verts: list[Gf.Vec3f] = [
(-x/2, -y/2, z/2),
(x/2, -y/2, z/2),
(-x/2, y/2, z/2),
(x/2, y/2, z/2),
(-x/2, y/2, -z/2),
(x/2, y/2, -z/2),
(-x/2, -y/2, -z/2),
(x/2, -y/2, -z/2)]
targetMesh.CreatePointsAttr(verts)
# autocalculate the extend based on a pointmesh of the verts
targetMesh.CreateExtentAttr(
UsdGeom.PointBased(targetMesh).ComputeExtent(verts))
# set the mesh to use no subdivision (i.e. default Polygonal mesh)
targetMesh.CreateSubdivisionSchemeAttr().Set(UsdGeom.Tokens.none)
# create 6 faces, each with 4 corner verts, and assign to vertex
faceVertCnts: list[int] = [4, 4, 4, 4, 4, 4]
targetMesh.CreateFaceVertexCountsAttr(faceVertCnts)
# assign the 4 defined verts to the 6 faces (righthanded)
indices: list[int] = [
0, 1, 3, 2,
2, 3, 5, 4,
4, 5, 7, 6,
6, 7, 1, 0,
1, 7, 5, 3,
6, 0, 2, 4]
targetMesh.CreateFaceVertexIndicesAttr(indices)
# assign the face normals
normals: list[Gf.Vec3f] = [(0, 0, 1), (0, 1, 0), (0, 0, -1), (0, -1, 0), (1, 0, 0), (-1, 0, 0)]
targetMesh.CreateNormalsAttr(normals)
targetMesh.SetNormalsInterpolation(UsdGeom.Tokens.uniform)
return targetPrim
