CUDA 12.x crt/math_functions.h: noexcept redeclaration mismatch with modern glibc (2.38+) in C++17
# Solving the CUDA 12.x + Modern glibc (2.38+) noexcept Redeclaration Failure
> **Status.** Verified end-to-end on **Fedora 44, CUDA 12.8 (nvcc), clang 22, GCC 15, Python 3.14 + PyTorch** — the extension compiles and the `.so` loads. The compiler-detection and version-parsing logic is written to generalize across distros (Debian/Ubuntu, Arch, openSUSE, Alpine), but those paths are derived from the same mechanism rather than separately tested; treat them as “should work,” not “verified.”
> **Try the cheapest fix first.** These two problems are independent — you may only need one:
> - If a **CUDA-supported GCC is installable** on your system (≤13 for CUDA 12.0–12.3, ≤14 for 12.4+), and your **glibc is < 2.38**, you likely need nothing in this guide beyond `-ccbin g+±13` (or `CUDAHOSTCXX=g+±13`). Stop there.
> - You need the full workaround below only when you are forced onto **GCC ≥ 14** (the EDG built-ins problem, §4 Layers 1–2) **and/or** you are on **glibc ≥ 2.38** (the `noexcept` math conflict, §4 Layer 3). The two are orthogonal: a supported GCC does *not* avoid the glibc math conflict, and an old glibc does *not* avoid the GCC built-ins problem.
## 1. The Problem
CUDA 12.x combined with modern glibc (2.38+) and GCC 14+ introduces a three-layer incompatibility that prevents compilation of CUDA kernels:
**Layer 1: EDG Parser Limitation**
NVCC’s EDG front-end (the C++ parser CUDA uses internally) does not recognize the compiler built-ins that GCC 14+ libstdc++ uses to implement standard traits — `__is_pointer`, `__is_volatile`, `__array_rank`, `__is_invocable`, `__builtin_operator_new`, `__builtin_is_virtual_base_of`, and others. Parsing `<type_traits>`/`` from a GCC 14+ installation then fails with a burst of `identifier “__is_pointer” is undefined` / `type name is not allowed` errors. Note this is independent of the host compiler *version check*: `–allow-unsupported-compiler` silences the check but cannot make EDG understand the built-ins.
**Layer 2: glibc math Function Declarations**
Starting with glibc 2.38, the file `bits/mathcalls.h` declares standard math functions like `cospi`, `sinpi`, and `rsqrt` with exception specifications (`noexcept(true)`), enabled when compiling in C++17 mode. This is correct modern C++ practice.
**Layer 3: CUDA crt/math_functions.h Mismatch**
CUDA’s `crt/math_functions.h` declares the same functions *without* exception specifications, treating them as functions that may throw. When the preprocessor encounters both declarations, the C++ standard rules forbid redeclaration with differing exception specifications—it is a hard compilation error.
**Layer 4: Macro Cascade**
When glibc’s preprocessing machinery renames the conflicting function symbols (via `__DECL_SIMD` macros), those renames propagate through CUDA’s header stack, creating additional unresolved symbol conflicts and circular dependencies.
## 2. Symptoms
Users will encounter one or more of these errors:
error: declaration of ‘double cospi(double)’ has a different exception specifier
   than previous declaration 'double cospi(double) noexcept'
error: too many arguments for option – ‘Xcudafe’
/usr/include/x86_64-linux-gnu/bits/mathcalls.h: In function ‘XXX’:
error: ‘XXX’ was not declared in this scope
error: unknown type name ‘__is_pointer’
These errors often appear even in minimal CUDA files and prevent any CUDA extension from building on systems with glibc 2.38+.
## 3. Root Cause
The upstream fix NVIDIA should apply is to add exception specifications to `crt/math_functions.h` to match modern glibc declarations. Until CUDA toolkits are updated, a build-time workaround is required.
The workaround exploits the C++ preprocessor’s include-path ordering and macro scoping to prevent the conflicting declarations from being evaluated by the compiler simultaneously.
## 4. The Workaround: Three-Layer Solution
**Which layers do you actually need?** Match your failing errors to the layers:
- `identifier “__is_pointer” is undefined`, `__builtin_operator_new`, `type name is not allowed` from `type_traits`/`functional` → **GCC built-ins problem → Layers 1 & 2.** Only triggered when the host compiler is GCC ≥ 14. If you can install GCC ≤ 13 (or ≤ 14 on CUDA 12.4+), prefer that and skip Layers 1–2 entirely.
- `exception specification is incompatible … cospi/sinpi/rsqrt … crt/math_functions.h` → **glibc `noexcept` math conflict → Layer 3.** Triggered by glibc ≥ 2.38 + CUDA 12.x regardless of compiler.
The `setup.py` in §5 applies all three automatically and is a no-op for layers your system doesn’t trip, so it is safe to use even if you only need one.
**Layer 1: Use clang++ as NVCC Host Compiler**
NVCC always parses device translation units with its own EDG-based front-end; the host compiler is not replaced. What the host compiler *does* control is the emulation mode EDG runs in — EDG adopts the host compiler’s predefined macros, built-ins, and default include paths. When the host is GCC ≥ 14, EDG emulates GCC but does not implement the newer built-ins (`__is_pointer`, `__builtin_operator_new`, etc.) that GCC’s libstdc++ now uses, so parsing fails. When the host is clang, EDG emulates clang, and clang provides those same built-ins, so the headers parse. Selecting `clang++` via `-ccbin` is therefore what eliminates the `__is_pointer` family of errors.
**Layer 2: Bind clang++ to a GCC ≤15 Toolchain**
clang still pulls libstdc++ headers from a GCC installation, and by default it selects the *newest* GCC present — which may be a version (e.g. GCC 16) that introduces still-newer built-ins such as `__builtin_is_virtual_base_of` that even clang’s emulation does not cover. We pin clang to a compatible GCC toolchain (version 15 or below) via `–gcc-install-dir`, and we feed that same pinned toolchain’s C++ include directories to NVCC’s front-end with `-isystem` so EDG and the host pass read identical headers.
**Layer 3: Intercept bits/mathcalls.h**
Before glibc’s `bits/mathcalls.h` is processed, we insert a compatibility shim that:
- Renames conflicting function names (e.g., `cospi` → `__compat_cospi`)
- Suppresses the `__DECL_SIMD` macro cascade by undefining it for the renamed symbols
- Includes the real glibc header via `#include_next`, which now operates on safe (renamed) symbols
- Restores the original macro definitions
- The renamed symbols never reach CUDA’s header declarations, avoiding the conflict entirely
## 5. Implementation
The following `setup.py` applies all three layers dynamically, with no manual configuration required beyond setting an environment variable.
```python
import os
import sys
import shutil
import subprocess
import tempfile
from pathlib import Path
from setuptools import setup
from torch.utils.cpp_extension import BuildExtension, CUDAExtension, CUDA_HOME
ROOT = Path(_file_).resolve().parent
def _parse_ver(s: str) → “tuple[int, …] | None”:
“”"Parse a version string like ‘12.3.0’ into a tuple of integers.
Returns a tuple of integers for comparison, or None if parsing fails.
try:
    parts = s.split(".")
if not parts or not parts[0].isdigit():
return None
return tuple(int(p) for p in parts)
except ValueError:
return None
def _find_gcc_base() → “Path | None”:
“”"Locate the GCC installation directory across all major Linux distributions.
Tries common installation paths for Debian/Ubuntu, Fedora/RHEL, Arch, openSUSE,
Alpine, and musl-based distros. Falls back to glob matching if none are found.
Returns the Path to the GCC base directory, or None if no installation is found.
candidates = \[
“/usr/lib/gcc/x86_64-linux-gnu”, # Debian/Ubuntu
“/usr/lib/gcc/x86_64-redhat-linux”, # Fedora/RHEL
“/usr/lib/gcc/x86_64-pc-linux-gnu”, # Arch
“/usr/lib/gcc/x86_64-suse-linux”, # openSUSE
“/usr/lib/gcc/x86_64-alpine-linux-musl”, # Alpine
“/usr/lib/gcc/x86_64-linux-musl”, # Void/musl
for c in candidates:
    p = Path(c)
if p.is_dir():
return p
# Fallback: glob for any x86_64 GCC directory
import glob
matches = sorted(glob.glob("/usr/lib/gcc/x86_64-\*/"))
return Path(matches[0]) if matches else None
def _get_compiler_search_paths(compiler_path: str, extra_args: “list[str] | None” = None) → list[str]:
“”"Query the host compiler to find its default system include directories.
Runs the compiler preprocessor in verbose mode and parses its output to extract
standard include paths. This ensures headers are sourced from the correct
toolchain version without any hardcoding.
IMPORTANT: pass the \*same\* toolchain-selection flags here that you pass to the
host compiler at build time (e.g. --gcc-install-dir=...). Clang otherwise
defaults to the newest GCC installed, which on a mixed system is exactly the
version whose libstdc++ intrinsics broke the build. The reported include paths
must match the GCC the host compiler is actually pinned to.
Args:
    compiler_path: Path to the compiler binary (e.g., '/usr/bin/clang++')
    extra_args: Toolchain-selection flags to forward (e.g. the --gcc-install-dir
        pin), so the reported paths correspond to the pinned GCC.
Returns:
    A list of absolute paths to system include directories, or an empty list if
    the compiler cannot be queried.
try:
    cmd = \[compiler_path, \*(extra_args or \[\]), "-E", "-x", "c++", "-", "-v"\]
    result = subprocess.run(
        cmd,
input=“”,
capture_output=True,
text=True,
check=True
    paths = \[\]
    in_search_list = False
for line in result.stderr.splitlines():
        line = line.strip()
if line == “include <…> search starts here:”:
            in_search_list = True
continue
if line == “End of search list.”:
break
if in_search_list and os.path.isdir(line):
            paths.append(os.path.abspath(line))
return paths
except Exception:
return []
def _find_compatible_host_compiler() → tuple[str | None, str | None]:
“”"Find a compatible host compiler and GCC toolchain pair.
Prefers GCC 13 or older if available (these don't trigger EDG parser issues).
Falls back to Clang with an explicitly chosen GCC ≤15 toolchain to avoid
modern GCC intrinsics that NVCC's EDG front-end cannot parse.
Returns:
    A tuple (compiler_path, gcc_install_dir) where:
      - compiler_path is the path to the C++ compiler binary
      - gcc_install_dir is the path to a compatible GCC toolchain (or None if
        the compiler_path is already GCC ≤15)
# 1. User override via environment variable
env_cxx = os.environ.get("CUDAHOSTCXX")
if env_cxx and shutil.which(env_cxx):
return env_cxx, None
# 2. Prefer older GCC versions (11 to 13) which work natively with NVCC
for ver in (“13”, “12”, “11”):
    gcc_bin = shutil.which(*f*"g++-{ver}")
if gcc_bin:
return gcc_bin, None
# 3. Fall back to Clang with a companion GCC ≤15 toolchain
clang_bin = shutil.which("clang++")
if clang_bin:
    gcc_base = \_find_gcc_base()
if gcc_base:
# List all installed GCC versions and find the highest ≤15
        installed_versions = sorted(
            \[p.name for p in gcc_base.iterdir() if p.is_dir()\],
key=lambda v: _parse_ver(v) or (0,)
        compatible_versions = \[
            v for v in installed_versions
if _parse_ver(v) and _parse_ver(v)[0] <= 15
if compatible_versions:
            target_ver = compatible_versions\[-1\]
return clang_bin, str(gcc_base / target_ver)
# 4. Final fallback: use system default compiler
default_cxx = shutil.which("g++")
return default_cxx, None
def build_extensions():
“”"Build CUDA extensions with automatic compatibility handling.
Checks if CUDA_EXT_ENABLE environment variable is set to "1". If not,
returns an empty extension list (CUDA support is optional).
Creates a temporary compatibility shim directory, generates the bits/mathcalls.h
wrapper, configures the NVCC compiler with compatibility flags, and returns
a CUDAExtension configured to use these settings.
use_cuda = os.environ.get("CUDA_EXT_ENABLE", "0") == "1"
if not (use_cuda and CUDA_HOME):
return []
host_cxx, gcc_install_dir = \_find_compatible_host_compiler()
# Create a temp directory in /tmp (guaranteed space-free) for generated files
# Use PID to avoid collisions in multi-process builds
compat_root = Path(tempfile.gettempdir()) / *f*"nvcc_compat\_{os.getpid()}"
compat_bits = compat_root / "bits"
compat_bits.mkdir(*parents*=True, *exist_ok*=True)
# Write the mathcalls.h interception shim
# This renames conflicting math functions and suppresses __DECL_SIMD macros
# to prevent redeclaration errors when glibc headers meet CUDA headers
shim_content = (
“/* CUDA/glibc noexcept compatibility shim — auto-generated */\n”
“#pragma push_macro(\“cospi\”)\n”
“#pragma push_macro(\“sinpi\”)\n”
“#pragma push_macro(\“rsqrt\”)\n”
“define cospi _compat_cospi_\n”
“define sinpi _compat_sinpi_\n”
“define rsqrt _compat_rsqrt_\n”
“\n”
“define _DECL_SIMD___compat_cospi_\n”
“define __DECL_SIMD___compat_cospi__f\n”
“define __DECL_SIMD___compat_cospi__l\n”
“define __DECL_SIMD___compat_cospi__f32\n”
“define __DECL_SIMD___compat_cospi__f64\n”
“define __DECL_SIMD___compat_cospi__f128\n”
“define __DECL_SIMD___compat_cospi__f32x\n”
“define __DECL_SIMD___compat_cospi__f64x\n”
“define _DECL_SIMD___compat_sinpi_\n”
“define __DECL_SIMD___compat_sinpi__f\n”
“define __DECL_SIMD___compat_sinpi__l\n”
“define __DECL_SIMD___compat_sinpi__f32\n”
“define __DECL_SIMD___compat_sinpi__f64\n”
“define __DECL_SIMD___compat_sinpi__f128\n”
“define __DECL_SIMD___compat_sinpi__f32x\n”
“define __DECL_SIMD___compat_sinpi__f64x\n”
“define _DECL_SIMD___compat_rsqrt_\n”
“define __DECL_SIMD___compat_rsqrt__f\n”
“define __DECL_SIMD___compat_rsqrt__l\n”
“define __DECL_SIMD___compat_rsqrt__f32\n”
“define __DECL_SIMD___compat_rsqrt__f64\n”
“define __DECL_SIMD___compat_rsqrt__f128\n”
“define __DECL_SIMD___compat_rsqrt__f32x\n”
“define __DECL_SIMD___compat_rsqrt__f64x\n”
“\n”
“#include_next <bits/mathcalls.h>\n”
“\n”
“#undef _DECL_SIMD___compat_cospi_\n”
“#undef __DECL_SIMD___compat_cospi__f\n”
“#undef __DECL_SIMD___compat_cospi__l\n”
“#undef __DECL_SIMD___compat_cospi__f32\n”
“#undef __DECL_SIMD___compat_cospi__f64\n”
“#undef __DECL_SIMD___compat_cospi__f128\n”
“#undef __DECL_SIMD___compat_cospi__f32x\n”
“#undef __DECL_SIMD___compat_cospi__f64x\n”
“#undef _DECL_SIMD___compat_sinpi_\n”
“#undef __DECL_SIMD___compat_sinpi__f\n”
“#undef __DECL_SIMD___compat_sinpi__l\n”
“#undef __DECL_SIMD___compat_sinpi__f32\n”
“#undef __DECL_SIMD___compat_sinpi__f64\n”
“#undef __DECL_SIMD___compat_sinpi__f128\n”
“#undef __DECL_SIMD___compat_sinpi__f32x\n”
“#undef __DECL_SIMD___compat_sinpi__f64x\n”
“#undef _DECL_SIMD___compat_rsqrt_\n”
“#undef __DECL_SIMD___compat_rsqrt__f\n”
“#undef __DECL_SIMD___compat_rsqrt__l\n”
“#undef __DECL_SIMD___compat_rsqrt__f32\n”
“#undef __DECL_SIMD___compat_rsqrt__f64\n”
“#undef __DECL_SIMD___compat_rsqrt__f128\n”
“#undef __DECL_SIMD___compat_rsqrt__f32x\n”
“#undef __DECL_SIMD___compat_rsqrt__f64x\n”
“\n”
“#pragma pop_macro(\“rsqrt\”)\n”
“#pragma pop_macro(\“sinpi\”)\n”
“#pragma pop_macro(\“cospi\”)\n”
(compat_bits / "mathcalls.h").write_text(shim_content)
nvcc_args = \[
“-O3”,
“–use_fast_math”,
“-std=c++17”,
“–expt-relaxed-constexpr”,
“–allow-unsupported-compiler”,
f"-I{compat_root}"
# Specify target architectures
# Adjust these based on your target GPUs (sm_80 for A100, sm_90 for H100, etc.)
nvcc_args += \[
“-gencode”, “arch=compute_80,code=sm_80”,
“-gencode”, “arch=compute_89,code=sm_89”,
“-gencode”, “arch=compute_90,code=sm_90”,
# If Clang is selected with a companion GCC toolchain, create a wrapper script
if host_cxx and “clang” in host_cxx and gcc_install_dir:
    wrapper_path = compat_root / "clang_host_wrapper.sh"
    wrapper_script = (
“#!/bin/sh\n”
f’exec “{host_cxx}” --gcc-install-dir=“{gcc_install_dir}” “$@”\n’
    wrapper_path.write_text(wrapper_script)
    wrapper_path.chmod(*0o*755)
    nvcc_args += \["-ccbin", *str*(wrapper_path)\]
# Inject the companion GCC toolchain’s C++ include paths into NVCC’s own
# frontend. These MUST be queried with the same --gcc-install-dir pin the
# wrapper applies, otherwise clang reports its default (newest) GCC headers
# and NVCC’s frontend parses libstdc++ intrinsics from the wrong GCC version.
    gcc_dir_flag = \[*f*"--gcc-install-dir={gcc_install_dir}"\]
for sys_path in _get_compiler_search_paths(host_cxx, gcc_dir_flag):
if “c++” in sys_path:
            nvcc_args += \["-isystem", sys_path\]
elif host_cxx:
    nvcc_args += \["-ccbin", host_cxx\]
# Build the CUDA extension
# : Update the name, sources, and include_dirs to match your project
return [
    CUDAExtension(
name=“<my_package>.cuda_ext._ops”, # e.g., “my_project.cuda_ext._ops”
sources=[
str(ROOT / “bindings.cpp”), # C++ bindings to CUDA kernels
str(ROOT / “kernel.cu”), # CUDA kernel source
extra_compile_args={
“cxx”: [“-O3”, “-std=c++17”],
“nvcc”: nvcc_args,
include_dirs=[str(ROOT)],
setup(
name=“<my_package_cuda_ext>”, # e.g., “my_project_cuda_ext”
version=“0.0.0”,
ext_modules=build_extensions(),
cmdclass={“build_ext”: BuildExtension.with_options(use_ninja=False)},
## 6. Build Command
To enable CUDA support and build the extension:
```bash
export CUDA_EXT_ENABLE=1
python setup.py build_ext --inplace
To disable CUDA support (builds without CUDA code):
```bash
export CUDA_EXT_ENABLE=0
Or simply omit the environment variable entirely; it defaults to “0”.
## 7. Why This Works (Technical Detail)
**The #include_next Mechanism**
The C++ preprocessor processes `include <bits/mathcalls.h>` by searching the include path in order. When we inject our compatibility shim directory first (via `-I<compat_root>`), the preprocessor finds our `bits/mathcalls.h` wrapper instead of the system one.
Our wrapper:
1. Renames conflicting symbols using macros (`cospi` → `_compat_cospi_`)
2. Stubs out the `__DECL_SIMD_*` macros to prevent automatic vectorization declarations that would otherwise propagate renamed symbols downstream
3. Calls `#include_next <bits/mathcalls.h>`, which causes the preprocessor to resume searching *after* our wrapper and find the *real* glibc header
4. The real header’s declarations and macro expansions now operate on the renamed symbols (which glibc never heard of), so no redeclaration conflict occurs
5. The pragma pop/push mechanics restore the original macro names so CUDA code can still use `cospi` and friends—they just reference the renamed versions
**Clang + GCC Toolchain**
NVCC’s EDG front-end emulates whichever host compiler is passed via `-ccbin`. With clang as that host, EDG inherits clang’s built-ins and accepts the GCC 14+ libstdc++ intrinsics (`__is_pointer` and friends) that a GCC-emulated EDG rejects. Pinning clang to a GCC ≤15 toolchain with `–gcc-install-dir`, and passing that toolchain’s C++ headers to NVCC via `-isystem`, keeps still-newer GCC 16 intrinsics (e.g. `__builtin_is_virtual_base_of`) out of both the front-end parse and the host compile. The `-isystem` paths must be derived from clang *with the same `–gcc-install-dir` pin applied* — querying an unpinned clang reports its default (newest) GCC headers and silently reintroduces the very version you are trying to avoid.
**Temporary Directory Isolation**
Using `/tmp/nvcc_compat_` ensures the generated wrapper script and shim are placed in a filesystem location guaranteed to be writable and free of spaces, even on systems where the project root may contain special characters or be mounted in restricted ways (Docker, NFS, etc.).
**Version Parsing**
The `_parse_ver()` function handles arbitrary version strings like “12.3.0” or “15.0.1” by splitting on dots and converting each component to an integer. This allows robust comparison of GCC versions without relying on fragile string comparisons.
## Appendix: Troubleshooting
**Error: “clang: error: unsupported option ‘–gcc-install-dir’”**
Your Clang version is too old (pre-11.0). Upgrade Clang or set `CUDAHOSTCXX=g+±13` to force GCC.
**Error: “no GCC installation found”**
Ensure GCC is installed. On Debian/Ubuntu: `sudo apt install g+±13`. On Fedora: `sudo dnf install gcc-c++`. The script will auto-detect it.
**Error: “too many arguments for option – ‘Xcudafe’”**
You are likely running an older version of this script that includes the `-Xcudafe` flags. Update to the latest version above, which has removed those flags.
**Error: “declaration … has a different exception specifier”**
The shim was not injected (the `-I<compat_root>` flag is missing). Ensure `build_extensions()` is being called. You can add diagnostic output: add `print(f"Shim at: {compat_root}")` before returning the extension list and verify the path appears in your build output.
**Permission Denied on Wrapper Script**
Ensure the temp directory has execute permissions. The `wrapper_path.chmod(0o755)` call should handle this, but on some systems `chmod` may fail if the filesystem is mounted `noexec`. Try setting `TMPDIR` to a writable directory: `export TMPDIR=$HOME/.tmp; mkdir -p $TMPDIR; python setup.py build_ext --inplace`.
