Cuda 3.2 Memory Kernel Error
Hello All,
I am having a weird problem in a kernel where I am assigning a certain value for a variable “mm” that varies in a loop.
This mm is then used as an index for an array pointer that is already loaded.
In many cases if the variable “mm” exceeds a certain limit, the program crashes giving some errors like:
First-chance exception and Microsoft C++ exception: cudaError_enum at memory location
The weird part is that if mm was fixed even for a much higher number, the program works well.
This is the main code that cause the crash:
mm=i*480;
					if(mm>=100000)
							rd = ptr2[1];
					else
						rd = ptr2[mm]; //
// Note that if this was fixed to even a higher value like 100001, no problem then
