Hi!
Installing CUDA-5.0 in my Debian host is ok, but I can not compile CUDA examples.
The compiling stopped with next error message:
/usr/local/cuda-5.0/lib64/libcudart.so: undefined reference to `std::__detail::_List_node_base::_M_unhook()@GLIBCXX_3.4.15'
/usr/local/cuda-5.0/lib64/libcudart.so: undefined reference to `std::__detail::_List_node_base::_M_hook(std::__detail::_List_node_base*)@GLIBCXX_3.4.15'
There is additional information about my system:
~/NVIDIA_CUDA-5.0_Samples$ uname -a
Linux debian 2.6.32-5-amd64 #1 SMP Sun Sep 23 10:07:46 UTC 2012 x86_64 GNU/Linux
myHost@debian:~/NVIDIA_CUDA-5.0_Samples$ gcc -v
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 4.4.5-8' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.4 --enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4 --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --with-arch-32=i586 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.4.5 (Debian 4.4.5-8)
myHost@debian:~/NVIDIA_CUDA-5.0_Samples$ echo $PATH
/usr/local/cuda/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
myHost@debian:~/NVIDIA_CUDA-5.0_Samples$ echo $LD_LIBRARY_PATH
/usr/local/cuda/lib64
myHost@debian:~/NVIDIA_CUDA-5.0_Samples$ nvcc -V
Copyright (c) 2005-2012 NVIDIA Corporation
Built on Fri_Sep_21_17:28:58_PDT_2012
Cuda compilation tools, release 5.0, V0.2.1221
I think that my problem is standard one, but google does not help me.
Thanks in advance.
