Trying to have cuda 7.5 working on a ubuntu 14.04 machine.
I installed from deb following instructions:
http://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html
The Desktop is installed by a Quadro K2200 and a Quadro 4000. Both listed here as GPU valid:
https://developer.nvidia.com/cuda-gpus
I compiled deviceQuery, which shows (even if run as super user):
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 10
-> invalid device ordinal
Result = FAIL
this appears in the syslogs:
[ 2152.593188] NVRM: RmInitAdapter failed! (0x25:0x1c:1379)
[ 2152.593215] NVRM: rm_init_adapter failed for device bearing minor number 1
[ 2152.593248] NVRM: nvidia_frontend_open: minor 1, module->open() failed, error -5
I did run the script shown here, but that did not help:
http://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#runfile-verifications
Some details:
cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module 352.79 Wed Jan 13 16:17:53 PST 2016
GCC version: gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.3)
from /etc/dev, ls -al | grep nvidia
crw-rw-rw- 1 root root 195, 0 Okt 27 17:02 nvidia0
crw-rw-rw- 1 root root 195, 1 Okt 27 17:02 nvidia1
crw-rw-rw- 1 root root 195, 255 Okt 27 17:02 nvidiactl
lspci -vv | grep NVIDIA
03:00.0 VGA compatible controller: NVIDIA Corporation GM107GL [Quadro K2200] (rev a2) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 1097
03:00.1 Audio device: NVIDIA Corporation Device 0fbc (rev a1)
04:00.0 VGA compatible controller: NVIDIA Corporation GF100GL [Quadro 4000] (rev a3) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 0780
04:00.1 Audio device: NVIDIA Corporation GF100 High Definition Audio Controller (rev a1)
cat /etc/modprobe.d/blacklist-nouveau.conf :
blacklist nouveau
options nouveau modeset=0
environment variables:
CUDA_HOME
/usr/local/cuda-7.5
PATH:
/usr/local/cuda-7.5/bin:/usr/local/cuda-7.5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
LD_LIBRARY_PATH
/usr/local/cuda-7.5/lib64:
