Cuda and array of strings Reading/Writing to Array of Strings
I am new to cuda not new to c programming. I am trying to build an array of strings to send to global memory and have each thread grab a particular string from the array. I would assume you would use cudaMallocPitch to do so. How would one allocate/read/write to such an array if passed to the kernel.
I think you would allocate the memory like this.
[codebox]char** d_data;
unsigned int pitch;
cudaMallocPitch((void**) &d_data, &pitch, sizeof(char)*MAX_STRING_SIZE, NUMBER_OF_STRINGS);[/codebox]
However, how would one work with it in the kernel. I have tried different ways with no luck.
Using cuda 2.3
computability 1.1
Thanks,
Steven
