We have 4 GPUs on a node and I intend to use the GPUs on the node to run an executable with the same input file, inputFile and a parameter file, parmFile (however with different parameters
on each CPU thread <=> GPU).
Since only one CPU thread can use a GPU, can I be guaranteed that if I do the following on the node,
./exefile inputFile
./exefile inputFile
./exefile inputFile
that these will run on three different CPUs?
The parameter file has the device ID (which is passed to the cudaSetDevice within the code) and an input parameter, p is changed for each run.
Note that the parameter file is changed before I invoke each executable.
Hence, for example, ./exefile inputFile could run on a gpu with device ID 0 for a certain input, p1
./exefile inputFile runs on a gpu with device ID 1 for a certain input, p2
