Hello.
( sorry bad english )
Use Slackware64-14.2 kernel-4.17.9
Same problem mentioned in previous posts.
Later versions of NVIDIA-Linux-x86_64-396.24.run do not recognize cuda .
Below is some information.
NVIDIA-Linux-x86_64-396.45.run
nvidia-modprobe -u -c 0
ls -l /dev | grep -i nvidia
crw-rw-rw- 1 root root 195, 0 Jul 23 09:10 nvidia0
crw-rw-rw- 1 root root 195, 255 Jul 23 09:10 nvidiactl
crw-rw-rw- 1 root root 195, 254 Jul 23 09:10 nvidia-modeset
crw-rw-rw- 1 root root 511, 0 Jul 23 09:12 nvidia-uvm
crw-rw-rw- 1 root root 511, 1 Jul 23 09:12 nvidia-uvm-tool
$ nvcc -V
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Tue_Jun_12_23:07:04_CDT_2018
Cuda compilation tools, release 9.2, V9.2.148
./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 30
-> unknown error
Result = FAIL
crw-rw-rw- 1 root root 195, 0 Jul 23 09:28 nvidia0
crw-rw-rw- 1 root root 195, 255 Jul 23 09:28 nvidiactl
crw-rw-rw- 1 root root 195, 254 Jul 23 09:28 nvidia-modeset
crw-rw-rw- 1 root root 511, 0 Jul 23 09:29 nvidia-uvm
crw-rw-rw- 1 root root 511, 1 Jul 23 09:29 nvidia-uvm-tool
$ nvcc -V
./deviceQuery
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 1050 Ti"
CUDA Driver Version / Runtime Version 9.2 / 9.2
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 4037 MBytes (4233035776 bytes)
( 6) Multiprocessors, (128) CUDA Cores/MP: 768 CUDA Cores
GPU Max Clock rate: 1418 MHz (1.42 GHz)
Memory Clock rate: 3504 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 1048576 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.2, CUDA Runtime Version = 9.2, NumDevs = 1, Device0 = GeForce GTX 1050 Ti
Result = PASS
[b]*detect correctly - NVIDIA-Linux-x86_64-396.24.run
*does not detect correctly - NVIDIA-Linux-x86_64-396.24.02.run
*does not detect correctly - NVIDIA-Linux-x86_64-396.37.run ( included in package cuda_9.2.148_396.37_linux.run )
*does not detect correctly - NVIDIA-Linux-x86_64-396.45.run[/b]
