Hello everyone!
i’ve found similar topics in the discussions, but some of them are slightly different, others don’t help
so, i have dll with the class implementation using CUDA code
dll project it’s pretty simple:
header file with the class declaration (no CUDA references at all)
.cu file with all of the CUDA code, including texture references and constant memory declaration
.cpp dll interface, containing DllMain
I should say that this class statically linked inside other project works perfectly.
So, i’m attaching this dll via LoadLibrary function. Objects of this class are created in the dll in the .cpp file and passing to the caller as pointers to the class instance. Objects are also deleted inside the dll by passing a pointer from the caller.
First time as i create and delete object everything is ok - cuda kernels works fine and fast =). When i try to create it second time (only after the first one is deleted!) two errors appears:
- cudaMemcpyToSymbol returned “invalid device symbol” in this code:
__constant__ float kernel [DIAMETER];
void init(){
cudaMemcpyToSymbol( "kernel", h_kernel, DIAMETER*sizeof(float) );
Adding “static device” to declaration didnt help
I commented error checking after cudaMemcpyToSymbol but another error appeared:
- “cudaBindTextureToArray” returns “invalid texture reference” in this code:
texture<float, 2, cudaReadModeElementType> tex1;
void init(){
tex1.addressMode[0] = cudaAddressModeClamp;
tex1.addressMode[1] = cudaAddressModeClamp;
tex1.filterMode = cudaFilterModePoint;
tex1.normalized = false;
cd = cudaCreateChannelDesc( 32, 0, 0, 0, cudaChannelFormatKindFloat );
cudaMallocArray( &(array1), &cd, width, height );
cudaBindTextureToArray( tex1, array1, cd );
I’m using msvs 2008 @ cuda runtime 3.2 @ win7 64-bit @ geforce gtx 580, drivers was updated today.
Should code inside dll be specially-managed? Maybe there should be some static declarations?
What will happen, if two caller instances will call same dll with CUDA code which uses texture references or constant memory?
