I just cloned the tensorrtx/yolov5 GitHub repository and I am trying to run the model. I followed all the instructions for it, however, when I run the following command: “sudo ./yolov5_det -s yolov5s.wts yolov5s.engine s” which I believe is to convert the yolo weights into engine file, I am getting the following error:
[01/08/2024-17:51:37] [W] [TRT] The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
Loading weights: yolov5s.wts
CUDA error 222 at /home/nvidia/Documents/tensorrtx/yolov5/plugin/yololayer.cu:32yolov5_det: /home/nvidia/Documents/tensorrtx/yolov5/plugin/yololayer.cu:32: nvinfer1::YoloLayerPlugin::YoloLayerPlugin(int, int, int, int, bool, const std::vector&): Assertion `0’ failed.
Aborted
NOTE: I have installed everything needed, and when I run some of the projects using DeepStream 6.2 SDK everything run normally, I don’t get any CUDA Error message. I am using Jetson Orin NX, with Cuda 11.8 and 11.4 installed, TensorRT 8.5.2.2
Is there anything I should do? Any help?
