I am building a TensorRT network using Python API and getting the following error when I call execute_async (to inference network):
[TensorRT] ERROR: ../rtSafe/cuda/genericReformat.cu (1246) - Cuda Error in executeMemcpy: 1 (invalid argument)[
There is no ANY debug information or smth that could help me to understand what am I doing wrong.
I have 2 GRU layers in my network, I construct each layer using Pytorch Weights (from GRU Cell) the following way:
module = ctx.method_args[0]
input_trt = #Layer input
hidden_trt = # Layer hidden
layer_count = 1
hidden_size = module.hidden_size
max_seq_len = 1
kernel_hh = module.weight_hh.detach().cpu().numpy()
rh = kernel_hh[:512,:]
zh = kernel_hh[512:1024, :]
hh = kernel_hh[1024:1536,:]
kernel_ih = module.weight_ih.detach().cpu().numpy()
ri = kernel_ih[:512,:]
zi = kernel_ih[512:1024, :]
hi = kernel_ih[1024:1536,:]
#bias = trt.Weights(torch_dtype_to_trt(module.weight.dtype))
# if module.bias is not None:
bias_hh = module.bias_hh.detach().cpu().numpy()
brh = bias_hh[:512]
bzh = bias_hh[512:1024]
bhh = bias_hh[1024:1536]
bias_ih = module.bias_hh.detach().cpu().numpy()
bri = bias_ih[:512]
bzi = bias_ih[512:1024]
bhi = bias_ih[1024:1536]
# reshape to 2D
layer_hidden = ctx.network.add_shuffle(hidden_trt)
layer_hidden.reshape_dims = (0, 1, -1)
layer_input = ctx.network.add_shuffle(input_trt)
layer_input.reshape_dims = (0, 1, -1)
layer_rep = ctx.network.add_rnn_v2(
input=layer_input.get_output(0),
layer_count=layer_count,
hidden_size=hidden_size,
max_seq_length = 1,
op=trt.tensorrt.RNNOperation.GRU)
layer_rep.hidden_state = layer_hidden.get_output(0)
print(layer_rep)
layer_rep.set_weights_for_gate(0,trt.tensorrt.RNNGateType.UPDATE, True, zi)
layer_rep.set_weights_for_gate(0,trt.tensorrt.RNNGateType.RESET, True, ri)
layer_rep.set_weights_for_gate(0,trt.tensorrt.RNNGateType.HIDDEN, True, hi)
layer_rep.set_weights_for_gate(0,trt.tensorrt.RNNGateType.UPDATE, False, zh)
layer_rep.set_weights_for_gate(0,trt.tensorrt.RNNGateType.RESET, False, rh)
layer_rep.set_weights_for_gate(0,trt.tensorrt.RNNGateType.HIDDEN, False, hh)
layer_rep.set_bias_for_gate(0, trt.tensorrt.RNNGateType.UPDATE, True, bri)
layer_rep.set_bias_for_gate(0, trt.tensorrt.RNNGateType.RESET, True, bzi)
layer_rep.set_bias_for_gate(0, trt.tensorrt.RNNGateType.HIDDEN, True, bhi)
layer_rep.set_bias_for_gate(0, trt.tensorrt.RNNGateType.UPDATE, False, brh)
layer_rep.set_bias_for_gate(0, trt.tensorrt.RNNGateType.RESET, False, bzh)
layer_rep.set_bias_for_gate(0, trt.tensorrt.RNNGateType.HIDDEN, False, bhh)
# reshape back to 1D
layer_res = ctx.network.add_shuffle(layer_rep.get_output(0))
layer_res.reshape_dims = (0, -1)
output._trt = layer_res.get_output(0)
If I remove these layers, then error disappears.
How can I debug it and while there is no open-source Python API available?
Thank you!
