Hi All,
I ran into a linking problem with a cuda fortran code (CUF). Demonstrated below with the matmul example from the manual. When using the -fPIC flag, the linker can not find libcublas.so.
Without the ‘-fPIC’ flag:
[ktomko@oakley02 ~/CUF_Examples]$ pgf90 -Mcuda=4.1 -o mmul_pgf90 mmul.cuf
With the ‘-fPIC’ flag:
[ktomko@oakley02 ~/CUF_Examples]$ pgf90 -fPIC -Mcuda=4.1 -o mmul_pgf90 mmul.cuf
/usr/bin/ld: cannot find …/…/2011/cuda/3.2/lib64/libcublas.so
If I add the -# flag to see all of the compilation steps here is what the ld command looks like:
/usr/bin/ld /usr/lib64/crt1.o /usr/lib64/crti.o /usr/local/pgi/12.5/linux86-64/12.5/libso/trace_init.o /usr/lib/gcc/x86_64-redhat-linux/4.4.5/crtbegin.o /usr/local/pgi/12.5/linux86-64/12.5/libso/initmp.o /usr/local/pgi/12.5/linux86-64/12.5/libso/f90main.o -m elf_x86_64 -dynamic-linker /lib64/ld-linux-x86-64.so.2 /usr/local/pgi/12.5/linux86-64/12.5/lib/pgi.ld -L/usr/local/pgi/12.5/linux86-64/12.5/libso -L/usr/local/pgi/12.5/linux86-64/12.5/lib -L/usr/lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.5 /tmp/pgf90cM5dg8U334jS.o -rpath /usr/local/pgi/12.5/linux86-64/12.5/libso -rpath /usr/local/pgi/12.5/linux86-64/12.5/lib -rpath /usr/local/pgi/12.5/linux86-64/2012/cuda/4.1/lib64 -o mmul_pgf90 -lcudafor4 -lcudaforblas -L/usr/local/pgi/12.5/linux86-64/2012/cuda/4.1/lib64 -lcudart /usr/local/pgi/12.5/linux86-64/12.5/lib/nonuma.o -lpgmp -lpthread -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lnspgc -lpgc -lrt -lpthread -lm -lgcc -lc -lgcc /usr/lib/gcc/x86_64-redhat-linux/4.4.5/crtend.o /usr/lib64/crtn.o
pgf90-Fatal-linker completed with exit code 1
One solution is to just not use -fPIC, however the code that I’m building is a hybrid MPI/CUF code and the MPI library invokes pgf90 with the two flags
-noswitcherror -fPIC.
The compiler version is:
[ktomko@oakley02 ~/CUF_Examples]$ pgf90 --version
pgf90 12.5-0 64-bit target on x86-64 Linux -tp nehalem
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2012, STMicroelectronics, Inc. All Rights Reserved.
I have a workaround using a customized mpif90 script, so not a show stopper for me.
-Karen
