Hi, All,
I’m new to CUDA Fortran. I’m testing CUDA Fortran and comparing with CUDA C. According to my test, for a same problem, it seems CUDA Fortran is about 2 times slower than its CUDA C version.
I don’t know what’s wrong with my CUDA Fortran code. Maybe I missed something when compiling the CUDA Fortran version. I used the following command: pgfortran -fast xxx.cuf
Anyone has the same problem as me?
Hi lukeStar,
I’d need a specific example to understand what’s different. But unless you’re using textured memory, CUDA C and CUDA Fortran should have approximately the same performance.
I’m testing the cyclic reduction method to solve the tridiagonal system.
The method described in details in these two papers:
http://www.jcohen.name/papers/Zhang_Fast_2009.pdf
http://graphics.cs.ucdavis.edu/publications/print_pub?pub_id=978
The CUDA C version code can be found in the following link
http://cudpp.googlec…l/pcr_kernel.cu
Of course, I modified the original work to fit in my problem, but basically the core is the same. I first programmed a C version and then translated into Fortran. For 1.5 M nodes, my C version used about 68.6 s for 3000 iterations, while my fortran version used 161 s.
I checked my Fortran version code. There is one difference from the C version: I have 5 arrays (size = n) declared in shared memory in C version, but have only one array (size = 5*n) in shared memory in Fortran version.
Could this the reason cause the Fortran version slower?
Possible, but I doubt it. Can you post both your CUDA C and CUDA Fortran codes or send them the PGI Customer Service (trs@pgroup.com) and as them to forward them to me?
I already sent you the codes. Please have a test and let me know your results!
Hi lukeStar,
By default, CUDA Fortran uses a slower but more precise divide which appears to account for the difference. Compile with “-Mcuda=fastmath” to use the faster version.
My times:
30976 ms with CUDA C compiled w/ -O3
67696 ms with CUDA Fortran compiled w/ -fast
29309 ms with CUDA Fortran compiled w/ -fast -Mcuda=fastmath
Hope this helps,
Mat
Mat, Thank you so much for your helps!
I have more questions:
- When should we use option “-Mcuda = fastmath”
- Will this option affect the accuracy of results? I compared the results using two compile options. They do have little difference (from the 4th digit after point).
When speed takes precedence over accuracy.
Most likely, but to want extent will depend on the application.
What is the difference with the CUDA C version? I suspect it will be closer to the fastmath version.
