Hey everyone! I am trying to run the “run_nvidia_gpu” Command Prompt file for being able to use ComfyUI with my GeForce GT 710 graphics card rather than my CPU to hopefully get better performance and quicker outputs on AI generated images and short videos potentially. However, when I run that command, I get the “The NVIDIA driver on your system is too old (found version 11040). Please update your GPU driver by downloading and installing a new version from the URL: Official Drivers | NVIDIA Alternatively, go to: https://pytorch.org to install a PyTorch version that has been compiled with your version of the CUDA driver.” error. I am using the most up-to-date driver version (version 475.14) which I can verify through the GeForce Experience application. This driver runs CUDA 11.4, which I can verify through the release notes for the driver version and through running nvidia-smi: "±----------------------------------------------------------------------------+
| NVIDIA-SMI 475.14 Driver Version: 475.14 CUDA Version: 11.4 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce … WDDM | 00000000:01:00.0 N/A | N/A |
| N/A 0C P8 N/A / N/A | 394MiB / 2048MiB | N/A Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
±----------------------------------------------------------------------------+" (but I also got “nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Sun_Mar_21_19:24:09_Pacific_Daylight_Time_2021
Cuda compilation tools, release 11.3, V11.3.58
Build cuda_11.3.r11.3/compiler.29745058_0” after running the nvcc --version command, which shows CUDA 11.3, I’m not sure if that matters). I have downloaded PyTorch v1.12.1 for CUDA 11.3 (since I can’t find one that states it is compatible with CUDA 11.4) and have downgraded to driver version 466.77 that runs CUDA 11.3 to make it compatible with the PyTorch version before and I got the same error. Does anyone know how to fix this?
