I followed all the steps as mentioned in Getting Started with Jetson AGX Orin Developer Kit | NVIDIA Developer
But still when I ran jetson_release -v, I am getting the following message that cuda is not installed. Can you please help me?
idia@ubuntu:~/Desktop$ jetson_release -v
- NVIDIA Jetson UNKNOWN
- Jetpack UNKNOWN [L4T 34.1.1]
- NV Power Mode: MAXN - Type: 0
- jetson_stats.service: active
- Board info:
- Type: UNKNOWN
- SOC Family: tegra23x - ID:
- Module: UNKNOWN - Board: P3737-000
- Code Name: concord
- CUDA GPU architecture (ARCH_BIN): NONE
- Serial Number: 1421622124328
- Libraries:
- CUDA: NOT_INSTALLED
- cuDNN: 8.3.2.49
- TensorRT: NOT_INSTALLED
- Visionworks: NOT_INSTALLED
- OpenCV: 4.5.4 compiled CUDA: NO
- VPI: ii libnvvpi2 2.0.14 arm64 NVIDIA Vision Programming Interface library
- Vulkan: 1.3.203
- jetson-stats:
- Version 3.1.4
- Works on Python 3.8.10
Thank you,
Hi user158496,
Please try below two methods to install CUDA:
- Using apt command to install:
$ sudo apt update
$ sudo apt install cuda-toolkit-11-4
- Install deb file by manually:
Copy "cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb" file to target Orin
$ sudo dpkg -i cuda-repo-l4t-11-4-local_11.4.14-1_arm64.deb
$ sudo apt-key add /var/cuda-repo-11-4-local-xxxxx.pub
$ sudo apt-get update
$ sudo apt-get -y install cuda-toolkit-11-4
I tried both approaches, but getting the same status for cuda:
nvidia@ubuntu:~/Desktop$ jetson_release -v
- Board info:
- Type: UNKNOWN
- Libraries:
- cuDNN: 8.3.2.49
- TensorRT: 8.4.0.11
- Vulkan: 1.3.203
- jetson-stats:
- Version 3.1.4
in the sdkmanager, all the packages installed successfully.
I tried to flash the jetson orin with jetpack version 5.0 but still the same status for cuda.
This is the output of nvcc --version:
nvidia@ubuntu:~/Desktop$ nvcc --version
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Thu_Nov_11_23:44:05_PST_2021
Cuda compilation tools, release 11.4, V11.4.166
Build cuda_11.4.r11.4/compiler.30645359_0
nvidia@ubuntu:~/Desktop$ python3
Python 3.8.10 (default, Jun 22 2022, 20:18:18)
[GCC 9.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
torch.cuda.is_available()
False
This is the output of sudo apt install cuda-toolkit-11-4
Can you please help me with this error?
Many Thanks,
I think we need to clarify this…
Are you able to use CUDA or not? I mean currently it looks like the issue is “jetson_release -v” cannot tell you whether the CUDA is installed or not.
But nvcc is already installed and gave you ther version number. The issue looks like just “jetson_release” does not work well but not “cuda cannot be installed”.
Also, just in case you don’t know, this “jetson_release” is not an official tool released by us, so we are not sure whether it has problem in detecting or not.
I believe that jetson_stats has not been released by @rbonghi for JetPack 5.0 yet, so that may explain why jetson_release tool isn’t reporting correctly. If CUDA Toolkit can be found under /usr/local/cuda, then it should already be installed.
No, I am not able to use Cuda, the applications that need cuda, it will give me the error of Cuda not installed as well.
Is there anyway to make Cuda visible to system, I enabled CUDA_VISIBLE_DEVICES=0, 1 but still cannot detect cuda.
Can you please help me to make cuda visible to system?
Thank you,
The /usr/local/cuda is already there
and this is the last lines in ~/.bashrc:
export PATH=/usr/local/cuda-11.4/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda-11.4/lib64:$LD_LIBRARY_PATH
Thank you,
Are you able to run deviceQuery okay?
$ cd /usr/local/cuda/samples/1_Utilities/deviceQuery
$ sudo make
$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Orin"
CUDA Driver Version / Runtime Version 11.4 / 11.4
CUDA Capability Major/Minor version number: 8.7
Total amount of global memory: 30623 MBytes (32110190592 bytes)
(008) Multiprocessors, (128) CUDA Cores/MP: 1024 CUDA Cores
GPU Max Clock rate: 1300 MHz (1.30 GHz)
Memory Clock rate: 1300 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 167936 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.4, CUDA Runtime Version = 11.4, NumDevs = 1
Result = PASS
If that works, then your CUDA driver should be fine.
