CUDA-Kernel time measurement
what is the best possibility for the time measurement of CUDA-Kernels?
I use C++ - Timer and cudaThreadSynchronize() , but is it the best possibility?
timer.start();
kernel(...);
timer.stop();
There are the cudaEvents
Here’s a minimal example that makes use of it…
float memsettime;
cudaEvent_t start,stop;
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaEventRecord(start,0);
\cuda coda here
cudaEventRecord(stop,0);
cudaThreadSynchronize();
cudaEventElapsedTime(&memsettime, start, stop);
cudaEventDestroy(start);
cudaEventDestroy(stop);
I assume this is also reliable in timing non-CUDA code, right?
It depends I guess. If you have a CPU multi threaded program, cudaThreadSynchronize will do nothing synchronization wise so you would have to additionally include your own barrier. Other than that I guess it would work, although the phrase killing a fly with a bazooka comes to mind. (given the additional overhead of having to synchronize the cudaEvents’ timings).
Thank you!!!
