I have a problem compiling CUDA Mex files on a Mac with Snow Leopard. -
When calling the function I get the following error:
“(…) Library not loaded: @rpath/libcudart.dylib (…)”
I found this post here, where the problem seems to be similar. Unfortunately, his solution did not solve my problem.
I am using the same command lines:
system(sprintf('/usr/local/cuda/bin/nvcc --machine 32 -I"%s/extern/include" --cuda "my_cuda_mex.cu" --output-file "my_cuda_mex.cpp"', matlabroot));
mex -I/usr/local/cuda/include -L/usr/local/cuda/lib -lcudart -lcufft my_cuda_mex.cpp
and I also added the " -Xlinker -rpath /usr/local/cuda/lib " at the end of LDFLAGS in the maci section of the mexopts.sh file.
What else can I do?
I am using a MacBook Pro with a CUDA 3.0 installation and MATLAB R2009a (32bit).
Thank you in anticipation!
rgds
