CUDA & modulos
I wrote some pieces of code using the modulo operators, and noticed that these, especially in comparisons, give weird results.
Example:
#include <stdio.h>
#include <assert.h>
#include <math.h>
#define BLOCKSIZE 512
__global__ void kfinddiv(int *d_a, int k)
	long long idx = gridDim.x*blockIdx.y+blockDim.x*blockIdx.x+threadIdx.x;
	if (idx+2 < k/2)
		if (k%(idx+2) == 0)
			*d_a = idx+2;
int main()
	int input;
	scanf("%d", &input);
	dim3 dimGrid(int(ceil(float(input/BLOCKSIZE))), int(ceil(float(input/BLOCKSIZE))));
	dim3 dimBlock(BLOCKSIZE);
	printf("%d\n", int(ceil(float(input/BLOCKSIZE))));
	int *d_a;
	int *h_a;
	h_a = (int*)malloc(sizeof(int));
	cudaMalloc(&d_a, sizeof(int));
	*h_a = 0;
	cudaMemcpy(d_a, h_a, sizeof(int), cudaMemcpyHostToDevice);
	kfinddiv<<< dimGrid, dimBlock >>>(d_a, input);
	cudaMemcpy(h_a, d_a, sizeof(int), cudaMemcpyDeviceToHost);
	printf("%d\n", *h_a);
	return 0;
This works fine when compiled with -deviceemu, but as soon as it starts running on the real deal the modulo seems to be wrongly evaluated.
Does anyone know whether, or when this will be fixed. (I’m 100% sure it is the modulo operator: add an if(idx == 0 && k%(idx+2)) at the end and use an even number as imput and you’ll see what I mean. then try removing the modulo portion)
I am confused you index computation
If you want to sweep all elements of 2-D data, then it should be
long long idx = (gridDim.x*blockIdx.y+blockDim.x)*blockIdx.x+threadIdx.x;
second you have race condition on updating *d_a
if (idx+2 < k/2)
		if (k%(idx+2) == 0)
			*d_a = idx+2;
Could you provide CPU version, then we can check your parallelized version?
