When I installed CUDA for my RTX 4050M laptop, I had the intention of opening it up on Microsoft Visual Studio 2022 when I was making a new project, I made sure to delete GeForce Experience & install the latest drivers. But when I chose the Express method and the install kept failing, even just choosing the CUDA packages and rejecting other packages like GeForce Experience, Drivers, & HD audio. None of it worked. Can anyone give me the help I need? Ask me for more information if necessary.
From the installation result, you have installed in VS2022 successfully.
So can you restart your VS to double check ? Also you can check if there is “CUDA” listed under All languages.
When I say restart, I just mean close Visual Studio 2022 and Reopen.
Can you please confirm if there is C:\Program Files\Microsoft Visual Studio\2022\Enterprise\Common7\IDE\Extensions\NVIDIA\CUDA 12.3 Wizards folder in your machine. Some files are in it.
If there is and you VS2022 still can’t find CUDA, I would suggest you uninstall all and install again.
The above screenshot shows you have “Nsight VSE” installed successfully, but not “Visual Studio Integration”. I never see this issue before. Can you please try to install this separately ? And check the install result. Also please tell me what exactly Visual studio version you use. Thanks !
