I did a trace of application
In this report file:
When I select “CUDA → CUDA Summary” in the drop down
Under the Runtime API calls item in the table
% Time - 80.66
Launches
% Device Time - 15.46
All the other time percentages are nearly 0%
so my question here is that where is the rest of the 19.34% of Time and 84.54% of Device Time? That is, if they mean percentage to completely different ‘Total Time’ values?
I used thrust vectors to copy back and forth my data. In the “Memory Copy” section of this report, all the % Time values for memo copy for my run are apparently negligible.
But guess what, when I click the ‘summary’ link of the Runtime API Calls (which has its % Time value as high as 80.66), I immediately see that the culprit - ‘cudaMemcpy’ with its ‘Capture Time %’ value as high as 73.75 in this ‘Runtime API Calls Summary’ page.
does this mean that my bottle neck are still those call to thrust::copy(), even the “Memo Copies” section of the report doesn’t show it?
and how can I really find the exact function call that is the most expensive to me in general?
how does timeline feature help with any of these?
